11-21-2012, 11:14 PM | #23 |
BimmerPost Supporting Vendor
8250
Rep 18,839
[Updated FAQ]
I am currently on software version 231E now. Are there any benefits to updating to 240E? If 190E or earlier, we recommend updating to at least 231E, preferably 240E. At this time, the update path from 231E to 240E seem to be primarily focused on emissions, with no change in performance. However, there is no harm in updating to 240E if desired.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
11-23-2012, 06:44 AM | #24 |
Rep 97
Hi, interesting thread!
Is there any difference in new and old ECUs when it comes to the tuning or read/write time? I heard newer hardware versions (2011- or so) take much longer to read than 2008 for example. And that it isn't possible to read out the whole ECU in the newer versions as well. Do you tuners have to approach the 2011- cars any differently than the older ones? Thanks Chris |
11-23-2012, 12:16 PM | #25 |
Rep 97
Another question .
Given my setup stays stock, what would the estimated outcome be with the tune and the same standard fuel? The dyno below was done with 95 ROZ fuel which is I believe 93 Octane over in the US. I would not want to put any different fuel in to achieve more power. Here is my dyno, 2 runs: Leistung is whp SAE and Drehmoment is wtq. Software is 170E |
11-23-2012, 02:18 PM | #26 | |
Rep 810
01-03-2013, 09:33 PM | #28 |
8250
Rep 18,839
BETA Version Expired
For those receiving a "BETA Version Expired" message, a new E-Flash software suite from ESS has been released. Build version still remains at 0559, no specific feature changes at this time.
If you are receiving this message, please contact us directly with your full name & email address for an updated version.
01-03-2013, 09:37 PM | #29 |
10830
Rep 27,609
This is def the way to go as far as Tunes go guys. ESS + EAS can't go wrong with that combo.
Ill be getting my new m3 set up with ESS and EAS in a few weeks!
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST! Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101 vipfinance@bmwofcamarillo.com for warranties! |
01-04-2013, 10:39 AM | #30 |
Rep 159
Easy to use with very good support. I had my base file updated to the latest version when I did my tune. Im looking forward to loading ESS supercharger software with my cable if I can get it past the wife this spring.
01-04-2013, 02:37 PM | #31 |
8250
Rep 18,839
Awesome, you will even be able to retain the same cable when going boosted.
01-04-2013, 03:22 PM | #32 | |
Nüburgring Nordschleife BTG 8:05
49
Rep 826
ESS V2 Tune, ACM Test Pipes, AA Green Filter,Custom painted Recaro Pole Positions, Akrapovic slip on, Stoptech ST60/ Pagid pads, KW Clubsports, APEX ARC8s/Pilot Sport Cups, Hamann carbon fiber hood, ONEighty Headlight mod (selfmade), CRT lip with splitters, Blacked out/paint matched emblems, black aluminum extended paddles and pedals
02-19-2013, 04:11 PM | #33 |
8250
Rep 18,839
Note: E-Flash Software Suite v.10 released today.
For those that receive a "Device may be incorrectly coded" error when attempting to read your DME, you may be using v.9 or earlier software. If you have purchased your E-Flash interface from us, please contact us for an updated version of E-Flash Software Suite. FAQ updated.
03-07-2013, 06:21 PM | #34 |
8250
Rep 18,839
Just wanted to share a recent ESS E-Flash before/after dyno session on a 2009 M3 with some minor bolt-ons. The only thing missing was a performance flash tune.
ESS's E-Flash was immediately added and the M3 strapped to the dyno. The results were very impressive. Vehicle 2009 BMW M3 DCT Modifications Macht Schnell Performance Filter Fabspeed Resonated X-Pipe (primary catalysts intact) Rogue UnderDrive Pulley Remus Race axleback Options [X] Update to 240E (previously on 200E OS) [X] Remove cold start cat heat cycle/camshaft phasing (for smoother cold starts) [X] Retain OEM Rev limiter (customer specified) [X] Remove top speed governor/VMAX M3 was originally on 200E OS, which was updated to 240E before applying the ESS flash tune. Plugs were already changed approximately 500mi ago as part of scheduled maintenance. As you can see, gains are achieved throughout the entire powerband. Those with 93 at the pump can expect even better results Dyno added to post #3.
03-15-2013, 11:05 PM | #35 |
10830
Rep 27,609
Just wanted to bump this thread and the awesome walkthrough video that EAS has for the eflash process.
I was working with AJ@ESS on a few things with my ESS kit software and I was a little fuzzy on what to do throughout the process and wanted to just double check and the video was very helpful in confirming everything. Thanks again for making that video EAS!
03-17-2013, 12:05 PM | #36 |
Rep 988
Tempted to do this tune through EAS since I'm in the OC...
How is the reliability of this tune on the track? Engine doesnt run hotter than stock? Timing isn't so aggressive that the engine starts having to pull alot of timing? Any graphs that show this after the engine is well heat soaked? |
03-18-2013, 11:34 AM | #37 | |
8250
Rep 18,839
03-18-2013, 11:34 AM | #38 | ||
8250
Rep 18,839
03-18-2013, 12:07 PM | #39 | |
Rep 988
I am assuming with the software I can always re flash back to the oe softwre for track use on a hot day with socal 91 oct correct? However the cable is not stand alone and I would need a computer to switch? Would be pretty awesome to switch via iPhone or iPad or a handheld switcher. Also, rather than running race fuel on the track as that can get very pricey... Has anyone ran water meth on the M3 to raise octane levels? And prevent timing retardation and engine knock? I still have my water meth kit from my 2010 GTI as well as a case of Snow Performance Boost Juice... Hmmm |
03-18-2013, 12:17 PM | #40 | |
8250
Rep 18,839
Simply bring race gas with you to the track or use the Torco Accelerator additive. We use the same additive on our S/C applications when race gas isn't readily available.
04-29-2013, 02:42 PM | #41 | |
8250
Rep 18,839
Update
After a bit of testing, ESS has just released V2 of their E-Flash software for Akrapovic-equipped users with revised drivability/response.
Here's an independent review from member SROC5: Quote:
For more information, please contact EAS or ESS directly via phone or email.
05-28-2013, 06:24 PM | #42 |
8250
Rep 18,839
A quick look at the new v2 E-Flash cables which are now shipping:
05-28-2013, 07:56 PM | #43 |
Rep 1,359
I was a DirectFlash user and this weekend upgraded to the E-Flash cable. I got the 240E OE software (coming from 190E) and the V2 Akra Evo tune as well. The E-flash is way faster that the DirectFlash tool, and also gives you the capabilities to read and clear codes. As always, ESS' service is excellent (Thanks AJ!! ). The car is running great!!! Definitely runs smoother now. This V2 tune is not supposed to increase HP when compared to V1 but I'm curious if upgrading to 240E gave me any ponies. Was doing 377whp (std) with the OE 190E (along with mods in signature). Will take the car to the dyno soon to find out.
I would definitely recommend to ESS customers with the DirectFlash tool to upgrade to the E-Flash cable.
2014 E63 AMG-S
2012 C63 AMG (P31) - gone 2011 E90 M3 FBO - gone |
05-30-2013, 08:53 AM | #44 | |
391
Rep 3,149
Tags |
e-flash, ess, software, supercharged, tune |
