      03-17-2018, 03:02 PM   #1
ciscospirit
Austria
10
Drives: BMW M8 Competition (F93)
Unhappy Audible and feelable vibration noise during breaking after lowering
Hello,
i did a car lowering few days ago:
I posted here my KDS protocol: http://www.6post.com/forums/showpost...01&postcount=7
the handling is fine and no warping also with high speed, but if I slow down slightly (also if i do it hard) from 160km/h to 100 km/h the whole car is vibrating and it is also hearable.
I also feel this vibration at my break pedal.
But the steering wheel does not pull.
I also can notice this vibrations by lower speed slow down, but only very little feelable. Hearable it is just at higher speed, and there you hear it very loud.
The dealer also changed the brake fluid after the lowering, maybe there was a problem? or the suspension adjustment? or a not right fitting wheel?
does anybody has an idea what this could be?
some told me, it could be the brake disc but i think this would be a great coincidence directly after lowering, or?
I have on Monday again a date with the dealer.
      03-18-2018, 06:03 AM   #2
upstate650
upstate650's Avatar
2020 BMW M340xi  [0.00]
Originally Posted by ciscospirit View Post
Hello,
If you haven’t already, start with an alignment. They need to be realigned after a spring install after they have settled.
      03-18-2018, 11:48 AM   #3
ciscospirit
Austria
10
Hello,
oh okay... as far as I know, they just did it directly after the spring installation. didn't know that this need to be done twice.
I will force this tomorrow again...
what about my first alignment?
it is in german, but here is a quick google translation:
hinterachse = rear
vorderachse = front
sturz = fall
spur = track
fahrachswinkel = thrust angle
spur differenzwinkel = track difference angle
nachlauf = trailing
spreizung = spreading
rad versatz = Wheel offset
      03-19-2018, 11:22 AM   #4
upstate650
upstate650's Avatar
Hello,
hinterachse = rear
vorderachse = front
sturz = fall
spur = track
nachlauf = trailing
Realignment immediately after spring install will get you most of the way there, but it should really be done after they settle.
      03-19-2018, 05:57 PM   #5
ciscospirit
Austria
10
Hello,
Was today again at two different official dealer and booth take a test drive and told me after that the same: my rear disc-breaks are damaged and i should replace it with new onces.
They meant thats normal behavior after 60.000 km, that this could be needed to replaced. They all meant, it can‘t be a wrong alignent, otherwise it would be noticeable by driving too and not just by slowing down...
Tomorrow i know if they would replace it for free or not...
      03-23-2018, 08:03 PM   #6
ciscospirit
Austria
10
Exclamation
Hello,
since I would have had an appointment for the brake change today, I checked my brakes again beforehand and then discovered that:
The wheel hub is completely damaged at the rear. As if someone had ground here, scratched with a screwdriver and hit it with a hammer, so that it was dented and even broken! The spot is about 5 cm long and was exactly between 2 spokes.
Does anyone have any idea how it could come to such a damage? The vehicle has never had an accident and it is simply inexplicable how something like that can happen. This explains the vibration noise now ...
Anyway, have an appointment with the dealer again on Monday and will complain, because that can definitely not happen by itself ...
      03-23-2018, 08:51 PM   #7
AZ_Bmw_550
Drives: 2015 BMW 650i GC
2011 BMW 550i  [0.00]
That's really bad looking. I wonder if it fell off the jackstand when you had the springs installed. It almost looks like that rotor is completely distorted. Best of luck with a good resolution.
      03-24-2018, 09:51 AM   #8
ciscospirit
Austria
10
yah, i am also wondering how this could happen... but normally you didn't need to take off the breaks for spring installation or?
on monday i know more. i just hope that no discussion will start like "it was already before blablabla..." anyway, also if it was before, at the installation of the springs, somebody had should notice that and inform me about it.
on the other hand, the problem with the slow down vibrations started after spring installation, so i think it happened at the installation. other hand, the installation is 2 weeks ago and the damage looks already a bit old and dirty... hmm...
      03-24-2018, 04:59 PM   #9
Errowen
Drives: 2016 640i xDr GC MSport
That's the hub cover. What you can see of the rotor, which is very little, looks fine.
      03-24-2018, 07:01 PM   #10
Stumpel
Stumpel's Avatar
37
Drives: 2018 M3 ZCP 6mt
I think whoever installed the suspension owes you two new rear rotors. It looks as if they dropped the rotor onto the hat or whacked the hat with a hammer. I would insist on OEM replacements. Good luck.
      03-27-2018, 04:12 PM   #11
murph914
murph914's Avatar
66
Drives: 2014 650i Convertible
yep looks like it fell off, or they jacked on the hub to lift and hold the suspension while they installed the suspension. They should replace them with OEM and throw in new pads.
