07-06-2015, 07:50 PM | #1 |
Rep 146
Seat belt and shoulder pain
Well, I'm coming up on two years of happy ownership of my car all except for one thing. The seatbelt is causing me quite a bit of discomfort almost to the point I don't want to use it. It restricts and pulls on the shoulder too much.
Does anybody know if there's a device on the market or contraption that will reduce the seatbelt tension? |
07-06-2015, 10:50 PM | #2 |
Rep 327
07-06-2015, 11:45 PM | #3 | |
Rep 64
07-07-2015, 04:46 AM | #4 |
Certified Car Nut
94
Rep 458
The seatbelt tension is to protect you in the event of a collision. A seatbelt that is too slack will not prevent you hitting the steering wheel or dashboard in the event of a collision.
It is more likely that you have not adjusted the seatbelt mount on the B-pillar (if indeed this is adjustable on your car model) to suit your height so I would raise it or lower it so it fits correctly. Pads as suggested may also cushion the belt running across you. I would not alter the seatbelt tensioner or mounts in any way. I believe this is also a MOT fail in the UK.
Current: 2018 Range Rover Velar First Edition D300 HSE + 2018 AMG GT-C Coupe + 2013 6 Series BMW GranCoupe (October) Retired: 2016 AMG-GTS Coupe, 2013 & 2012 Maserati GranTurismo MC Stradale,2016 3-Series Touring, 2009 5 Series GT, 2007 BMW M5, 2012 & 2006 BMW 1 Series |
07-07-2015, 08:58 PM | #5 | |
Rep 146
Unfortunately it isn't adjustable nor does a pad help. I was hoping there might be some gizmo that will raise the belt above the seat to take pressure off the top of the shoulder. |
