      05-23-2018, 10:39 AM   #23
tuco44
tuco44's Avatar
Drives: 2018 340i xDrive M Perf Edtn
I use the slider all the time in winter. Not so much in the summer as it is permanently on cold max. Works well, and is a simple concept.
Not sure why so many don't like it...???
2018 340i xDrive M Perf Edtn Sunset Orange
Previous BMWs - 19 others since 1971.
      05-23-2018, 10:59 AM   #24
BEM-S4
BEM-S4's Avatar
Drives: Dinan M235, Dinan Sport Wagon
Try going back to an E70 I love my winter beater but instead of a wheel in the center of the dash you have to navigate down a few levels in the climate system and adjust for each zone.
I'd kill for a wheel.
2022 Macan S
2016 F31 328i xDrive Sport Wagon
2006 E46 330ci ZHP Convertible
      05-23-2018, 11:21 AM   #25
afadeev
afadeev's Avatar
1163
Drives: F80 M3
Originally Posted by TheSpungos View Post
Per my BMW Genius appt last week: it changes the temp of the air blowing from that vent by +/- 5 degrees. So it you have your climate control set to 70 and you turn it all the way blue, the air from that vent will be approx 65 degrees. All the way red and it will be approx 75 degrees.
It has definitely been more than +/- 5 degree change on all my bimmers, once you turn the face blower temp wheel.
In the winter, turning into max "blue/cold" range give you a blast of freezing outside air in your face, regardless of HVAC temp setting.
Basically, the dial is a simplified version of multi-level/multi-zone temperature controls you will find in a Rolls. But way simpler, and covers 99% of the needs.
Very helpful.
Most people like it, once the understand how it works (well described in the manual, that few read).
Few people don't understand how it works, so we share our experience on this forum. Then they get it.
And then there is an obligatory guy who just loves to hate stuff.
Pick a feature, wash-rinse-repeat.
a
'19 TM3P (BK/BK)
'15 F80 M3 (SO/SS)
ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's
      05-23-2018, 11:27 AM   #26
rackjuediger
rackjuediger's Avatar
Drives: 2013 328i 6mt
2013 BMW 328i  [0.00]
I find it most useful when my temperature is set at 70-75 degrees. If its cold out, I slide it to red, when its warm, I slide it to blue.
F30 328i 6mt
Injen, ER, BM3, Solowerks, IND, BMS, BBS
E46 M3 smg2
Bimmerworld, H
      06-04-2018, 01:04 PM   #27
zuckuss07
Drives: F30 328i M 6-Speed
I use the slider all the time. I keep my temp set to 70* usually. I use the slider to blend in some heat or some cool air at night. It takes a second. I think it's a great feature.
