      06-13-2014, 02:07 PM   #265
mr-karim
mr-karim's Avatar
Drives: F13 M6 (Fully Modded)
I didn't like +2.75 psi over stock, changed it to +3.25 psi over stock, and I must say car is way louder and more responsive. Going to keep it at +3.25psi for now, probably the best way to go, I can definitely feel over 600 horses at the wheels.
PS: I messaged Dinan, and asked about their tune and top speed limiter, here is the response
The M6 tune is still being finalized but considering it is the exact same engine as the M5 I think it would be safe to assume that the Stage 1 will produce the same numbers (610HP, 605 lb-ft of torque). These are all crank number as that is how BMW measures their power numbers. Stock M6 numbers are 560HP and 500 lb-ft of torque by the way.
In regards to the top speed limiter being removed… at this time the D-TRONICS Performance Tuner does not remove the speed governor however it is sophisticated and is designed to integrate into ALL systems. That means that when/if the top speed governor is eliminated amongst a myriad of other possibilities that the unit is already capable of implementing the feature with a quick update to the software via Bluetooth.
-Dinan
610hp crank is extremely bad for such a high price in my opinion, my best dyno result with BMS was 622 horses at the wheels, which is 715hp crank. Not bad, considering that BMS costs under $500
"The best things in life are free. The second best are very expensive." - Coco Chanel.
      06-13-2014, 02:22 PM   #266
C's Bimmer
C's Bimmer's Avatar
Drives: '15 M6 GC,'08 M5,'14 958 GTS
-Dinan
I wonder what it would be with the Comp Package, since HP is 575...
Current Garage:
*2015 Singapore Grey F06 M6 Gran Coupe (The Beast)
*2014 Black Cayenne GTS 958 (Wife & Kids Beast)
*2008 Imola Red E60 M5 (My Other Beast)
      06-13-2014, 06:34 PM   #267
gmd2003
gmd2003's Avatar
352
Drives: 2014 CP M6 and 2006 VT 525 Z4M
Originally Posted by JoeyLeeBMW
I daily on the old firmware at 2.5 x 1.44 = 3.6 PSI right now on 91 Octane in Los Angeles, CA
Joey you have a CP m6 with the same mods as I do, did you ever get it it dyno'd at you're current BMS settings ? Any performance numbers (60-130 or 1/4 mile , Vbox , etc ) from both 2.25 and 2.5? I just wonder if you're trading low end torque for high end power bc of knock detection . I've been running mine on the stock new firmware 3.0 settings and have had modest performance gains but nothing earth shattering .
      06-13-2014, 07:16 PM   #268
mr-karim
mr-karim's Avatar
      06-13-2014, 07:35 PM   #269
Andym3100k
Singapore
110
Drives: 2014 M6 GC FULL HAMMAN WIDE BO
2014 M6 GRAN COUPE FULL HAMANN WIDEBODY.
BR TUNE STACK ON BMS JB4 BCM METH/ UPGRADE SNAIL,ZEX 100 WET SHOT, CUSTOM COLD AIR INTAKE
SS DP/ FULL ARKA SYSTEM/ CHARGE PIPE TWIN NOZZ METH/NOS.BC 19" RIMS NT05R 345/30/19
      06-13-2014, 10:44 PM   #270
bigbrian
riding on rails
bigbrian's Avatar
Drives: 2o13 m6 f13
-Dinan
I read somewhere where someone dyno'ed a stock M6 and it was 580-585hp to the wheels. I don't understand how their tune would only produce 610hp to the crank. That doesn't make a whole lot of sense unless I am way off track here.
Brian
/// 2o13 x5m e70 . velos tuned . 22" adv1 wheels . dropped on kw variant3 coilovers . passport 9500ci radar & jammer. gets groceries fast
      06-14-2014, 01:38 PM   #271
mr-karim
mr-karim's Avatar
Don't try to set BMS to +3.25 over stock, just got a very bad drive train malfunction, couldn't get my car to drive for 25 mins, when I finally got the car to drive, brought it home, change psi from +3.25 to +.2.75, added more engine oil, added the best fuel without ethanol, and drove for the car for a bit. Now the check engine light is gone, car runs fine.
      06-14-2014, 03:28 PM   #272
Andym3100k
Singapore
110
Same problem here but I don't think is the transmission fault, u should have misfire on a few cylinder check your code is still in the ecu. Terry suggested to gap the spark plug smaller 1st, btw I'm running fine with 4psi but got the misfire when I try to run 4.5psi with 98ron plus 2bottle of +6ron octane booster.( I was doing fine with 1bottle & 4psi)
      06-14-2014, 04:26 PM   #273
mr-karim
mr-karim's Avatar
bro, +4 PSI is WAAAY too much. My car didn't like +3.25. I will be selling my car in sept or oct, for now I'll keep my settings at +2.75 psi lol
      06-14-2014, 06:41 PM   #274
Schnell_1
Schnell_1's Avatar
23
Drives: 2013 F13
S63 AMG Coupe?
      06-14-2014, 08:26 PM   #275
mr-karim
mr-karim's Avatar
Originally Posted by Schnell_1 View Post
S63 AMG Coupe?
2013 McLaren MP-4, since 650s came out, the price for MP-4 is not bad at all! And it's just a lil slower than bugatti, factory uprated mp-4 kills the aventador.
      06-14-2014, 09:33 PM   #276
Schnell_1
Schnell_1's Avatar
23
Drives: 2013 F13
Not to thread hijack, but what's involved in the factory updating that's so desirable? I hear those MP4-12C's are very daily drivable.....
      06-14-2014, 09:59 PM   #277
Hunter5179
Hunter5179's Avatar
Drives: 2013 M6 Coupe
Yeah good call. The car can run higher boost but without adjusting the air/fuel mix for more fuel who knows when and how long you will be able to ride like that. If you drive hard a lot then it's best to have it at 2.75 and have no worries. If someone cracks the dme and we can adjust the fuel levels then +1000 LOL. That is why Dinan's tune is pathetic.
My Thread:
      06-14-2014, 11:24 PM   #278
mr-karim
mr-karim's Avatar
Agreed, Dinan's tune is a joke; A very expensive piggy back with +10whp realistically, but you get their fancy 2 year "warranty" lol. I wouldn't pay more than $500 for a tune unless someone really cracks the code, and removes the top speed limiter with no probs.
      06-15-2014, 04:31 AM   #279
Andym3100k
Singapore
110
Bro, did u chk whether any fault code left in the dme? Bcos I also like to know how the transmission response to the extra TO.
      06-15-2014, 08:59 AM   #280
mr-karim
mr-karim's Avatar
Check engine light was on for a few hrs, but now it's gone. I would have to book an appointment with BMW to check for error codes. Last time I checked for error codes, BMW charged me $134.5
      06-15-2014, 07:19 PM   #281
Andym3100k
Singapore
110
They r blood sucker.
      06-17-2014, 08:31 AM   #282
Andym3100k
Singapore
110
Bro, I thought of sharing these with you as a car lover.
It was posted about 2 hours ago at N54forum. I believe he has the fastest M6 now at 11.07s 1/4 mile.
Today, 08:31 PM
Originally Posted by*m6beast*
I believe that's where you had the problem. Try setting it at 4.5 again, but do a third gear pull, gradually to open throttle all the way to red line, then cruise for a bit and do it again. Try this a couple of times then do a fourth gear pull this is a longer gear and give the MAFs a longer adaption run. Then park the car for a while and do it again. By the second to third day you will feel the difference and you shouldn't have any problems.
Also I'm always running in M1traction control off S3 shift. After a couple of days of adapting you can drive how ever you want. Also with the dct you want to be in the closest gear if you decide to down shift for example not fifth to third will have a delay. Another good note be in a gear you want to race and then hit it that way the MAFs dont have any surprises. But like I said once she's adapted you can drive any way you want.
100 octane fuel
5lb boost increase
Or pump 93 with 50/50 water meth mix
5lb boost increase*
93 pump 100% meth
6lb boost runs strong
100 octane 100% meth
Good luck!
Sound super! I will try it out this Friday & hope that it works on my car, I'm very very disappointed that day after the misfire, I move over from N55 6series GC to a M6 GC just b cos of power different. The car body is exactly the same & I have spend a lot of time n effort on it, after knowing the limits of the N55 I have no choice but to move over to a M6. Now that u have shine some lights to it really make me feel more confident on the car again! Thanks so much n hope that you break into the 10s soon.
2014 S63TU M6 GRAN COUPE (Register 6/6/2014)
JB3 S1 w S2 BOARD otw (5-6psi here I come)
METH W FSB CONTROLLER otw
K&N INTAKE
SS DP otw & DELETED MID PIPE*
21" BC FORGE Front 265/30/21 Rear 295/25/21
MATT WRAP
      06-17-2014, 11:44 AM   #283
mr-karim
mr-karim's Avatar
Today, 08:31 PM
100 octane fuel
5lb boost increase
5lb boost increase*
93 pump 100% meth
Good luck!
K&N INTAKE
MATT WRAP
Hey man, actually fastest m5 with bms did 11.0 exactly, and m6 did 10.9 or something Would be sick to remove the top speed governor. After I got the drive train malfunction I drive on +2.75
      06-17-2014, 07:59 PM   #284
m6beast
m6beast's Avatar
185
Drives: stock m6
Mr-Karim, all you need is to let the car adapt on your boost increase.
You'll be fine, I've been running 6lb boost increase 100% meth 100 octane on my M6 with no issues an plenty of miles
Also been running 4lb boost increase 93 pump gas on my F10 M5 with no issues.
Key is letting the car adapt to new boost increase
Good luck!
G
ttm6
      06-17-2014, 08:11 PM   #285
Tylerstar
Tylerstar's Avatar
69
Drives: Straight Piped F10 M5, GTR
I agree with M6beast, I doubt the drivetrain malfunction had anything to do with the extra boost. I used to get that malfunction all the time in colder temps without a tune. Or when I went to higher speeds, so it could a multitude of problems.
      06-17-2014, 08:36 PM   #286
Tylerstar
Tylerstar's Avatar
69
I started at 3 with 93, immediately after I gave it hard 2nd/3rd pulls then gave it a break. Then multiple hard pulls up to 160 and I have had no problems. It could also be a bad fuel issue.
Tags
akrapovic, ams downpipes, bms tune, bmw m6 coupe, mods
