E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > 325i to 330i conversion successful! Dyno charts included!
Reply
      04-11-2010, 02:23 AM   #23
smellthebeans
smellthebeans's Avatar
Drives: LPCs
1990 325i  [0.00]
Originally Posted by e90pilot View Post
I believe the X3 3.0i has a 328i engine with a 3-stage intake manifold. The parts you need are the same. Can't confirm if the software will work though.
That's true look for the Si designator
The high output N52 is available
5er (2006) someone will correct me if i am wrong here.
X5 3.0si
X3 3.0si
Z4 3.0si
      04-11-2010, 07:10 AM   #24
3lusive
3lusive's Avatar
Drives: 2013 MINI JCW Hardtop
X5 3.0si
X3 3.0si
Z4 3.0si
That's right, they share the n52 engine.
Have you noticed a change in gas mileage?
      04-11-2010, 10:21 AM   #25
philsteroni
Drives: 325xi
This reminds me of the e36 328i mod that involves taking a e36 325i manifold because of its bigger airways...it was an easy way to get 15-20hp for less than 300$.
      04-11-2010, 03:17 PM   #26
konstantinosz4s23i
Drives: bmw z4 s23i
That sounds very good.Does anybody know if there is a 3.0 stroker kit for the 325si?
Kuf-tuning has a 3.2 stroker kit but it is too expensive.I think that it is possible a 3 litre stroker kit.What do you think?
      04-11-2010, 06:39 PM   #27
e90pilot
Freight Dawg
e90pilot's Avatar
Drives: E90 325i
Well mine already came as a 3.0L so I don't about a stroker kit. Those kind of things are really expensive and don't really give you much power.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors
      04-11-2010, 07:37 PM   #28
E92325i
E92325i's Avatar
Drives: E92 325i
Well done
I'm really curious to know if the 3 stage intake manifold off the 330i (3.0l) will fit onto a '07 325i but with the 2.5l N52. I've got a euro spec E92 325.
Also sorry for my incompetence but how does the software side of things work when it's installed, does powerchip just develop a custom map to suit the manifold mods?
      04-11-2010, 07:50 PM   #29
konstantinosz4s23i
Drives: bmw z4 s23i
You have the 325 3.0si n52 which outputs 218 ps or the 325 2,5si n52 which outputs 218 ps too?
      04-11-2010, 07:56 PM   #30
E92325i
E92325i's Avatar
Drives: E92 325i
He has the 3.0l n52 judging by his post
      04-11-2010, 08:01 PM   #31
konstantinosz4s23i
Drives: bmw z4 s23i
I am curius if i order all the internals of a 3.0l si 272 ps and adjust them to my n52 2,5si would this thing work?
      04-11-2010, 08:17 PM   #32
E92325i
E92325i's Avatar
Drives: E92 325i
Yeah im interested too since i have the 2.5L version of the N52 in my 325. I don't think there would be any issue with the manifold, etc fitting but the i don't know about the software side.
      04-11-2010, 08:29 PM   #33
konstantinosz4s23i
Drives: bmw z4 s23i
The software should be the same with the 3.0..i think there should not be a lot trouble about that.If it is possible i am in!
      04-11-2010, 08:35 PM   #34
E92325i
E92325i's Avatar
Drives: E92 325i
Yeah it could be the same but it could be different due to it being a 3.0l engine vs our 2.5l engine. I wouldn't know or have access to anyone in Australia that is able to flash it with E90 330i software so a custom tune/map would be my only solution
      04-11-2010, 10:59 PM   #35
jabwind51
Drives: '10 BMW 130is, '97 BMW M3/4/5
The other thing to consider might be about space issues in the 1 series vs the 3 series or the X3. It might just be more crammed around the intake manifold...? Does this make sense or does same engine
mean same space?
      04-12-2010, 01:04 AM   #36
SR|RED
Drives: 92' 180SX
Nice!
      04-12-2010, 10:13 AM   #37
mike-y
just another bmw douche bag
Drives: 1.9L of fury
very nice gains. about time someone did it correctly.. Though I think 18% losses is a little high for these cars. Those numbers are right on par with a few 328i dynos I've seen. I've seen a couple 330i 6MTs dyno around 220-230whp. but nevertheless, those are very good gains on a 325i, and you may get more once the software is figured out.
I've had a 330i intake manifold sitting in the closet for over a year.. guess it's time to actually use it now!.
      04-12-2010, 12:51 PM   #38
e90pilot
Freight Dawg
e90pilot's Avatar
Drives: E90 325i
I really want to get an exhaust too. That should help that little bit on the high end where the torque drops off a little. I was thinking about doing a compression test when I change the spark plugs again. I wanna see how much my mileage is affecting the car.
--Marcelo
      04-12-2010, 03:13 PM   #39
BlackBimmer1991
BlackBimmer1991's Avatar
24
Drives: Black f32 428i xdrive
anyone know if they would work for a E90 328
      04-12-2010, 07:26 PM   #40
Digitalinkartist
MrSixSpeed
Digitalinkartist's Avatar
Drives: e92 Garage Queen
Wish there was a baseline/before dyno to confirm gains.
Great mod and good job getting the word out on what is soon to become a must have 325/328 n52 mod.
      04-12-2010, 07:41 PM   #41
BlackBimmer1991
24
I was planning on gettin an exhaust but if i can spend the same amount of money and get so much more hp y not. either way i love working on my car
      04-12-2010, 09:42 PM   #42
philsteroni
Drives: 325xi
E90pilot: When you had you 330 intake manifold w/o the tune, was your car running ok? I would do this mod right now if it were'nt for the tune being 950$. If I wanted to drop 2 grand on 30hp I would just trade my car in for a 330xi and get the status with it as well...
Ps:I'm running 330 exhaust on my car and I could swear it gave me a little more pep .
      04-12-2010, 09:54 PM   #43
e90pilot
Freight Dawg
e90pilot's Avatar
Drives: E90 325i
In my case I had the tune installed before the intake, but the car will run fine either way. As for a befor dyno, I tried to get one but there was a miscommunication with the place that had the dyno. I've seen dynos of 325s at about 185 whp.
--Marcelo
      04-12-2010, 10:00 PM   #44
Juan.sidarta
Indonesia
48
Drives: ex-e92
+1 might as well add alittle and get a 335i for e92's haha.
Reply
Tags
330i coversion, active autowerke, manifold swap, n52, tune
e90post
