      12-06-2017, 09:01 PM   #1
dsifer91
Drives: 750i
Run flat slow leak
My dunlop run flat tire is slowly leaking, can I get it repaired? I heard it's not possible
      12-06-2017, 09:36 PM   #2
Walt White Coupe
Walt White Coupe's Avatar
24
Go to TireRack and look at the link for Dunlop. It can be repaired if nail/screw is not in the outer or inner most tread block. Must dismount the tire and put a 'mushroom' type plug with stem pulled trough the hole inserted from the inside of the tire. Some tire repair shops are afraid that you may have run the tire with no air for many miles and won't touch a repair. Keep air in it
Here's the link: https://www.tirerack.com/tires/tiret...jsp?techid=226
      12-11-2017, 06:15 PM   #3
dsifer91
Drives: 750i
got it repaired, thanks, nail was in it
