05-21-2017, 01:06 PM | #1 |
Rep 3,071
Remove Snap-in Adapter Base DIY
So I was tired of the adapter base taking up all that space in my console so I decided to remove. It was a five minute one tool job:
1. Separate plastic bottom from felt covered base with thin 2. Push down and pull felt base away from console 3. Push plastic adapter though felt base and set felt base aside 4. Open small door in rear of console and disconnect three wires, pulling out plastic adapter 5. Reinstall rubber mat. I covered the hole with black felt, but for about $35 you can order the full mat (oem 51169217615).
05-22-2017, 06:23 AM | #5 | |
Rep 3,071
Snap in Adapter
Here is one write up: http://www.2addicts.com/forums/showthread.php?t=1177288 I tried using it with an iphone 4 and it was always wonky
05-28-2017, 04:38 PM | #7 |
Rep 3,071
"Nice DIY - did it this morning to clear out some space. Many thanks for the write up!."
Now if we can only clean-up your avatar...Go Gators!
05-29-2017, 04:19 PM | #8 |
master chief
20
Rep 119
Haha - no chance - it's all about the U
03-15-2018, 07:28 PM | #9 |
Rep 25
my trunk lock button is on the box that holds the adapter. 2014 M6 Gran Coupe. Anyone figure out a way to deal w/this?
Flying Ace4984.50 |
03-16-2018, 03:59 PM | #10 |
Rep 631
center console
You can get a little plastic tray to fit in the present location. The internal of the center console is different. The part number for the tray is 51169217615. It is around $30. Turner has about the best price. The "floor of the storage space will not increase but you will add an "oddment" storage tray. The trunk lock button remains as is.
F06 M6 Grand Coupe CP
Flying Ace4984.50 |
03-16-2018, 04:13 PM | #11 | |
Rep 11,891
Is the GC and coupe different? OP has a Coupe and in his pictures it clearly shows that the switch never went away during the conversion. Or if you did this on your car, maybe the model year changed the location of the switch?
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) Last edited by Flying Ace; 03-16-2018 at 04:24 PM.. |
03-16-2018, 05:49 PM | #12 |
Rep 3,071
As you can see in the pic above the trunk lock is on the same wall as the 12 volt and usb and did not need to be removed. I have a 2013 convertible
03-19-2018, 12:20 AM | #13 | |
Rep 631
you can remove the base plate 84109215826 and install 51169206734. The trunk switch remains in place.
Flying Ace4984.50 |
05-08-2021, 10:19 AM | #14 |
Rep 8
I'm sorry for re-opening this old post, but I'm struggling to get the felt base out. Seems to be stuck in there so I'm at the point where if I can't get it out I'm going to get stuck into it with a hacksaw blade.
05-13-2021, 11:11 PM | #15 |
Rep 8
This is a great post which helped me get the phone holder out. One point to note, for my 2014 coupe 640i, to get the holder out, I had to slide it towards the back of the car while pushing down on the metal clip at the front of the holder. Then to disconnect the big block connector, there's a sliding lock which needs to rotate out and the block disconnects. The pink and blue connectors were a b*tch to disconnect, had to use a small flat blade screw driver to get the coloured clips off, but after working it for about 15 minutes, they finally disconnected. Now to buy the full coverage mat to cover the wire access hole and it's complete.
PS. I don't have the boot lock in the centre console. Pics: Last edited by JDMils; 05-13-2021 at 11:32 PM.. |
Tags |
adapter, console |
