05-10-2017, 01:33 PM | #1 |
318
Rep 203
BPC 650i (F12, F13) & 650i GC (F06) DME Tuning - +127 WHP / +117 WTQ Gain!
Hey guys,
I know a few of you were looking at DME tuning options for the N63TU so I wanted to share this with you. Here are some highlights of our tune, and what this means for you as a driver. - We have updated parameters such as boost, fuel & timing maps to optimise power delivery at all points throughout the powerband. - The Valvetronic Maps have been adjusted for better part and wide open throttle response, giving a more direct feel with the car. - Exhaust valves are open all the time in sport and sport + modes, giving the car a sporty sound while performance driving yet the ability to quiet it back down again in normal driving modes. - Rev limiters are the same unless requested to be bumped to 7200rpm - Cold start and cat disable on stage 2 off road tune can be enabled - Speed limiter is removed - If requested, we can unlock for bootmod 3 Supported Models 2013 - 2016 750i 750li (F01, F02) 2013 - 2018 650i (F12, F13) & 650i grand coupe (F06) 2013 - 2017 550i & 550i GT (F10) 2013 - 2018 X5 5.0 (F15) FACTORY 348 WHP / 397 WTQ Stage I 475 WHP / 514 QTQ +127 WHP / +117 WTQ Gain over factory DME Tuning Procedure This vehicle is tuned by Bench flashing the DME only. This requires the DME to be removed, and sent in for software modification and mailed back. If you are interested in purchasing a tune from us, please visit our website to order: https://bimmer-performance-center.my...tune-2013-2016 If you have any questions you may also PM me and I'll be sure to answer back. Thank you, John |
05-10-2017, 02:40 PM | #2 |
Rep 1,715
Those are great numbers! what supporting mods are required for that tune?
Do you have a tune for upgraded turbos for those looking to go with bigger turbos now or replacing them after they fail?
05-10-2017, 02:48 PM | #3 | |
318
Rep 203
We can custom tune a setup for you with bigger turbo's, we would just need to have the car here to make adjustments depending on which turbo's you're using. I don't believe we've done a N63TU with upgraded turbo's but its fairly similar to the S63TU which we've done a TON of tuning on with big turbo's. We actually have Ruben's 800+whp M5 on the Dyno today for some more tuning. |
05-10-2017, 03:24 PM | #4 | |
Rep 1,715
05-10-2017, 03:29 PM | #5 | |
318
Rep 203
We would love to see what a N63TU could do with upgraded turbo's. It would probably hurt some M5 owners feelings for sure. At least a stock M5... |
05-10-2017, 03:39 PM | #6 | |
Rep 1,715
NY is a BIG state, I'm a long way from NYC. I'd love to see what the N63tu can do as well! Even on moderate boost the numbers should be really impressive! How many lbs of boost are you using on your stock tune?
05-10-2017, 03:42 PM | #7 |
318
Rep 203
I'm on a tight schedule unfortunately or else I would definitely come say hello! I'm visiting some family in Long Island / Riverhead for the weekend.
Let me check with Bob on the specific boost and I'll get back to you on that one. Having just moved from Texas, now THAT is a big state! You can drive for 6 hours and only get to the nearest City in some cases. |
05-10-2017, 04:03 PM | #8 | |
Rep 1,715
Yes - Texas is big for sure!
05-15-2017, 08:13 AM | #10 | |
318
Rep 203
The JB4 should be taken off, but if you can find a way... if could be left on as long as all of the settings were zero'd out and not altering any parameters. Some people like to use it to monitor boost and that sort of thing. You just don't want a back end flash and a JB4 both altering the same parameters causing extreme timing or fueling changes. |
FSociety3812.50 |
08-12-2021, 07:16 PM | #13 |
Rep 113
Bring back a thread from the dead.
John, is this mod still available. You did some tuning on my naturally aspirated 2005 545i a while back, and I was impressed with the little you got out of that. I now have a 2015 650i GC that I would love to add some power to. If you see this please respond. I'd love to see what you guys can do. |
08-12-2021, 07:19 PM | #14 |
Rep 113
actually, looking at the pictures I think I was up there when you had that on the dyno. Joshua said you were getting some good power out of it. It's the right time-frame.
08-17-2021, 03:00 PM | #16 |
Rep 285
So get bm3 and flash it yourself. Very easy to do.
08-17-2021, 04:39 PM | #17 |
Rep 113
Yes, I know/ I was interested in the numbers without having to do downpipes. Plus I've had them do previous cars for me, and they did great work.
Just disappointed that they no longer offer the service. But with bm3 being available it probably isn't worth it for them. |
