04-13-2017, 07:24 AM | #1 |
Rep 330
Extremely slow downshifts
I just got my vehicle back from its annual service and as soon as I drove away, I noticed that when I downshift, instead of it being instantaneous, it takes approximately 1.5 - 2 seconds before the gear change happens. The gear number in the display changes instantly, but the actual mechanics of the gear change are heavily delayed.
It feels as if the car is in "Eco Pro" mode and has the shift harshness set to 1 (even though it is set to 3). But upshifts happen instantaneously, as normal. It makes the car feel like a Buick/Lexus with super slow gear changes and makes me really not want to drive it. It does seem to get a bit better (but not perfect) after 10 or 15 minutes or so in the car, but most of my trips are that length, so I am always experiencing it. I'm hoping it may be some sort of vehicle protection mode that is temporarily on after a recent oil change and that it will eventually go back to normal. But that could just be wishful thinking. Has anyone else experienced anything like this? |
04-13-2017, 06:11 PM | #3 |
Rep 676
Drives: 2015 M6 Gran Coupe
I've experienced this after a service at Beverly Hills BMW. I thought they gimped my car, but after a couple days everything returned to normal. They might have reset the adaptive driver feature and the computer was relearning your driving habits.
Warrior7531.00 |
04-14-2017, 07:32 AM | #4 | |
Rep 330
However, when I drove it yesterday afternoon, while the slow downshifts were still there, it did only last about 2 minutes, rather than 10+. So it looks like it might be getting better. I'll try it again today and see if things continue to improve or if it goes back to slow downshifts again. |
04-15-2017, 12:17 PM | #6 |
Rep 330
I did a "reset" on the adaptive learning and it immediately made the car drive like "normal".
However, in the past, some people have commented that such a fix was short-lasting (a couple of weeks or a mont), and they had to do the reset procedure again. Even if that is the case, at least I can do it myself, and not have to bring it into the dealership to do it. |
04-15-2017, 01:57 PM | #8 | |
Rep 592
04-15-2017, 02:23 PM | #9 |
Rep 330
The reset procedure that worked for me ...
1. Turn on car without your foot on the brake (so that the engine doesn't start) 2. Wait a couple of seconds for the dashboard to finish "lighting up" 3. Put your foot down all the way on the accelerator pedal (I didn't go past the kick down point) 4. Hold your foot on the accelerator for about 25 - 30 seconds (you might be able to hold it for less, but this is the amount of time that works for me) 5. Release your foot off the accelerator pedal 6. Put your foot on the brake and start the vehicle as per normal |
04-15-2017, 03:54 PM | #10 |
Rep 676
glad to hear it worked out!
04-15-2017, 07:42 PM | #11 |
Rep 330
04-16-2017, 01:57 PM | #14 |
Rep 330
I took another short drive today. The issue of course is still there.
I did however try and few things and discovered that if I have the foot even partially on the gas when I downshift, the shift is instantaneous. But if I am just coasting or have my foot on the brake, it is very lethargic. What that tells me is that it is an issue with the "logic" of the system, rather than the car not being able to complete a quick downshift. I also pulled off to the site of the road, did another "reset" and the car drove like normal after that. I shot a very quick video of a 4->3 and a 3->2 downshift, so you can get an idea of the delay. You can hear the paddle click, and the gear number changes instantly ... then about 1.5 seconds later, you see the RPMs rise when the actual gear change occurs. |
04-16-2017, 09:39 PM | #17 |
Rep 330
Car is stock.
I was hoping to rectify this issue without a trip back to the dealer. I find with these "intermittent" type issues (i.e.: it only happens for a certain amount of time, or it doesn't always exhibit the behaviour), often the dealer will experience it "working", and believe that they have fixed the issue. Except it will return after your pick up the car. |
10-28-2017, 03:43 PM | #19 |
Rep 15
Hey, I was wondering if your issue ever resolved itself. I am having the same lethargic downshifts that is also intermittent. I noticed that it started happening when the weather got a little cooler even though I park in a garage.
I did notice after the engine hits normal operating temps I would pull over and restart the car and boom, it goes back to normal. |
10-29-2017, 11:30 AM | #20 | |
Rep 330
What is also interesting is that if you turn on cruise control, then downshift, the gear change occurs instantaneously. So the transmission is able to do the quick downshifts, but just doesn't want to when driving normally (without cruise control on). Actually, I was just in the dealership this Friday and brought up the issue with the new foreman (as the previous one had left and my discussions with him hadn't carried forward). I am going to bring in the car again in the next week or two for them to look at it. They are going to see if their are any DCT software updates and then if not, they are going to submit a case to BMW in Germany if there is no obvious fix. They did this with my M4 drive shaft vibration issue and it was eventually resolved. I'll definitely post back here once I find out more. |
10-30-2017, 03:02 PM | #21 |
Rep 15
Thanks for the update!
After some deep research, I did find that a F10 M5 owner was having similar issues and that he took his car in for a transmission re-flash which seemed to correct the delayed downshifts. Waiting to here back to see if anything else was involved. I currently have a date with another SA Wednesday, I'll post up any updates as well hoping they can do the same procedure. |
