11-13-2016, 10:08 AM | #1 |
Rep 4
Fuse map and Steering warning light
In my poor attempt to hard-wire a radar detector, I cracked the overhead console plastic housing while trying to pull it down.
After I put everything back without touching the wires, the map lights stopped working. The main dome light works as it should with the door closing and opening and the passenger airbag warning light is operational. But I got a Steering warning light when I started the car. It reads: Continued driving possible. Consult service center. I suspect that I popped a fuse while trying to pull down the overhead console, but I couldn't fine any fuse map on the car. Does any member have a fuse map? I tried googling but can only find maps for the older generation. Thank you. |
11-14-2016, 07:19 AM | #2 |
Rep 3,071
The fuse map card is in the trunk on the right side where the trunk fuses are located.
11-14-2016, 07:22 AM | #3 |
Rep 3,071
Fuse location info
These might help
11-14-2016, 06:17 PM | #4 |
Rep 4
Thank you very much!
Problem with the steering warning sign is solved. I just need to clear the passenger air-bag warning light now (unplugged the overhead console without disconnecting the battery first. Another lesson learned.) Does anyone know which INPA cable I should get? |
