05-31-2018, 10:14 AM | #2 |
Rep 46
Two part question, my passenger side fog light just went out, I believe these are LED fog lights? So is there a bulb replacement or does the entire housing need to be replaced? Also does anyone know how to remove the housing or access the fog lights?
05-31-2018, 10:53 AM | #3 |
Rep 1,719
It's more likely that you have an electrical issue than all 3 LED bulbs burning out simultaneously. I would start by checking your fuses.
05-31-2018, 10:55 AM | #4 | |
Rep 46
05-31-2018, 12:04 PM | #5 | |
Rep 7,452
In regards to fog light removal...here's instructions from the online TIS website: https://www.newtis.info/tisv2/a/en/f...ights/IexcaPum As far as the fog light itself...it appears to be a single unit based on the part database...there are no individual bulbs offered...just one single unit: Last edited by Qsilver7; 05-31-2018 at 12:18 PM.. |
upstate650305.00 |
06-04-2018, 02:04 AM | #7 |
Problem Solver
111
Rep 416
No I just had a similar issue, water got into my connection and messed it up a bit. I was able to remove the bottom grill and access the plug on the left side of the housing on the side. That fixed my issue once I cleaned out the corrosion and reseated the connection.
06-06-2018, 12:18 PM | #8 | |
Rep 46
