      09-10-2019, 03:37 PM   #1
ExclusiveElectronics
Drives: M6
Exhaust Tips Help
Hey guys,
Do you know what size exhaust tips fit on a 2016 BMW M6 Gran Coupe?
And how easy are they to remove and install?
I was thinking about getting 4 of these: https://www.ebay.com/itm/1x-67MM-Inl...W/192891361411 would they work?
      09-10-2019, 10:38 PM   #2
Flying Ace
Flying Ace's Avatar
4985
Removal and installation is easy. Each tip is held on by a screw clamp.
      09-11-2019, 10:53 AM   #3
Drives: M6
Does anyone have instructions?
      09-11-2019, 02:00 PM   #4
Bmwtechgeek
Drives: Bmw m5
Just bend over at look. Loosen the clamp and the tips will slide off. Its so easy.
      09-12-2019, 01:20 PM   #5
xxTHIR13ENxx
Drives: M6 Gran Coupe
Can someone confirm these are the correct dimensions for the M6 exhaust?
I assume there are no differences with the Competition exhaust?
Inner diameter: 67mm
Length: 150mm
I thought I read somewhere that inner dia. should be 69mm and length no more than 120mm?
Thanks!
- Leo.
      09-12-2019, 02:06 PM   #6
KrazyKorean
KrazyKorean
KrazyKorean's Avatar
Drives: 2014 M6 Gran Coupe
The inner diameter of the exhaust tip can't be smaller than 69mm or it wont fit over the M6 outlet.
      09-12-2019, 03:15 PM   #7
xxTHIR13ENxx
Thank you for confirming.
What about the length, could it be 150mm or is it best to go 120mm?
      09-26-2019, 07:32 PM   #8
Drives: M6
Anyone have info?
Tags
exhaust
