01-06-2015, 02:56 PM | #23 |
Rep 647
Separate issue ? What could that be ? Seems like fueling issue to me, no I do not have any scanners
01-06-2015, 03:00 PM | #24 | |
riding on rails
117
Rep 655
Have you turned down the tune to 0 and made a hard pull? Does it still happen? If not progressively move to 1,2,3 and see when the issue presents itself. These cars should adapt (for the most part) as you turn up the tune. We started with a pull at 0, then +1, then +2, then +3, and finally +4. The air/fuel was the same across the range on all 5 pulls. I am almost wondering (as EuroKar said) if you have something else going on. You need to get an air/fuel sensor hooked up and monitor it while you are doing this otherwise we are just guessing. Brian |
01-06-2015, 03:22 PM | #25 | |
Rep 647
01-06-2015, 07:34 PM | #26 | |
Rep 792
He set up his meth kit the way I told him to set up, wiring and my install diagram. after sending me some logs and clearing stored codes car is hauling ass in every map. Map 0 Map 1 and Map 3 |
01-06-2015, 07:44 PM | #27 | |
Rep 647
01-07-2015, 07:45 PM | #29 |
riding on rails
117
Rep 655
Only on the weekends and only when the moon is in a specific alignment. Other than that is NA for me all day everyday.
Brian
01-07-2015, 07:46 PM | #30 | |
riding on rails
117
Rep 655
Brian
01-07-2015, 10:17 PM | #31 | |
Rep 792
Once you get everything I walk you through the whole process and get you going Good luck! G Last edited by m6beast; 01-07-2015 at 10:32 PM.. |
01-08-2015, 12:05 PM | #32 | |
riding on rails
117
Rep 655
Brian
