      01-13-2014, 05:14 PM   #1
RespectTheGC
RespectTheGC's Avatar
Drives: 2014 BMW 640xi GC
Replaced the stock reflectors with body colored ones
took about 20 mins. Taking off the left over double sided tape from the inside of the fender/bumper was the longest part.
      01-14-2014, 12:37 AM   #2
Laguna Beach
Drives: i7 M60 Sport Pro
nice job bud doing mine this weekend
      01-14-2014, 01:51 AM   #3
Krash7172
Drives: 2018 530e, 2020 X4
A necessary mod IMO. Nice
      01-14-2014, 11:43 AM   #4
ARam
ARam's Avatar
61
Drives: 2016 BMW X5M
Where are the instructions???
      01-14-2014, 12:27 PM   #5
M3lbournE92
Drives: E92 M3
+1
      01-14-2014, 01:16 PM   #6
///M3THOD
///M3THOD's Avatar
Drives: 991.2 GTS
If I am not mistaken.. they are just fastened in with double sided tape.
You need to pop the plastic rivets/screws of the wheel well housing and they you can clean up the residue from the double sided left on the inside of the bumper.
      01-14-2014, 10:19 PM   #7
RespectTheGC
Tools needed: Socket wrench, hair dryer(optional but makes the job easier), phone or camera.
-take before pictures
-Turn wheel all the way left to work on the right reflector/all the way right to work on the left reflector.
-where the wheel well meets the bumper you'll see 3 black hex cap screws(one on low, one slightly higher, and then one around the same height as the reflector. Remove all 3 screws
-with a hair dryer heat the reflector you want to remove with the hair dryer to loosen up the glue. I did 10 seconds per spot x2(lower reflector, middle, top) be careful not to heat for too long, it will mess up your paint or bumper.
-pull the black piece in the wheel well starting from the bottom slowly, the bumper slightly overlaps it so you have to be careful when pulling
-stick your hand inside and get it behind the reflector,(I used it to support the bumper around the reflector while i pushed the reflector in with my other hand).
-reflector pops out, double sided tape gets left behind(this part is the b%tch)
-now heat up the double sided tape that is left behind in the bumper and remove it all.(you want a clean flat surface, otherwise your new reflectors will not sit flush)
-once tape is all out install your new painted reflectors
-put 3 screws back in
-take after pictures
reflectors cost anywhere from $60-$90. I don't think Im allowed to post which website I got them from but PM me if you have any questions.
      01-14-2014, 10:34 PM   #8
Krash7172
This is a very easy mod. No heat required (and I wouldn't recommend heating myself)
http://www.6post.com/forums/showthread.php?t=903794
Edit: I did this on my 5 so I knew what I was getting into. My 6 was new and the adhesive came off easily. An older car may be more difficult...
      01-15-2014, 11:46 AM   #9
ARam
ARam's Avatar
61
Nice write-up. πŸ‘πŸ™ŒπŸ‘ŒVery tempted to do it for a weekend-day project. I wonder if i could spray paint these after dismounting. Don't want to have spare parts laying around.
      01-15-2014, 03:24 PM   #10
RespectTheGC
I sprayed the reflectors on my previous BMW. As long as you spray a clear coat over them then buff they will look great. You can get your BMW paint in a spray can from expresspaint.com
