      03-21-2018, 07:26 PM   #1
spikespiegel
Drives: BMW M6 comp
any issues w DSC/transmission with different tire sizes?
looking to switch to 4s's and at 275 fronts and 305 rears; any issues with the software and change in tire sizes? Thanks!
      03-22-2018, 02:20 AM   #2
mastatikle
Drives: m3
It depends, you will have issues if there is a significant difference between the rear and front tire diameter. If they are not close enough together the car will not shift right or consistently.
      03-22-2018, 03:19 AM   #3
Mr. M6
Mr. M6's Avatar
149
Drives: M6
2014 BMW M6 F06  [9.25]
i have 4s 265 front and 305 rear and no problem at all.
      03-22-2018, 10:25 AM   #4
spikespiegel
Drives: BMW M6 comp
Nice, thanks for posting Mr. M6.. Seems like 275 front would be fine too then since its a closer ratio..
      03-22-2018, 04:34 PM   #5
gregmb
master chief
gregmb's Avatar
Drives: 2014 ///M6 vert
I made the switch to those exact tires/sizes (4S plus 10 mm over stock width on factory 20" wheels) a couple months ago. Overall a positive - no issues no problems no errors no rubs - better traction with the rears hooking a bit better and slightly more sidewall protecting the wheels from curb rash if I happen to get too close. Will keeping running these sizes.
      03-22-2018, 06:08 PM   #6
BMWDriverX
Drives: G12 750i X-Drive
I was running 285/35 front and 315/30 rear with no issues except rubbing in the front. I replaced the front with a 265/35 and that fixed the rubbing, the 315/30 fixed the traction problems.
      03-22-2018, 06:25 PM   #7
spikespiegel
Drives: BMW M6 comp
jesus, you can run a 315!??
      03-22-2018, 06:36 PM   #8
BMWDriverX
Easily on a 10.5" wheel. I would not go past 305 on a 20x10 and 315 max on a 10.5
People have been running those sizes on those widths for years and years without any issues, including myself.
      04-12-2018, 04:19 PM   #9
spikespiegel
Drives: BMW M6 comp
one more question: is it fine to use a 10mm spacer in F and R with 275F and 305R's??
      04-13-2018, 11:18 AM   #10
gregmb
master chief
gregmb's Avatar
Presumably a 10 mm spacer on 275 front tires would be the equivalent to running a 285 size tire. As mentioned above, a 285 size in the front creates rubbing issues when turning.
