      10-28-2016, 02:00 AM   #1
gokudo_90
Drives: 2020 X5 M50i
steering heavy on one side
i currently own a 2014 650i with integral active steering, for some reason after returning from the track, steering is heavier when turning to the right side while light on the left side.
i took the car to the dealer to check it multiple times, they have changed the steering rack 3 times now and still issue not solved.
i have read on many forums that changing the steering rack should solve it, but in my case it didn't, i have changed the front tires, and waiting for my rear tires to arrive to change them.
but I'm pretty sure tires aren't the case here, to be frank, it feels like when turning left the active steering is working, but when turning right the active steering doesn't work.
anyone can faced a similar issue? my dealer is oblivious on how to solve it as my car is one of 2 or 3 in the country with integral active steering
      10-28-2016, 06:26 AM   #2
F30Andy
F30Andy's Avatar
1771
Drives: An Entire Fleet
Have they flashed the ECU yet?
      10-28-2016, 08:03 AM   #3
gokudo_90
how do they flash the ECU? im not sure, i read their report and it only mentions changing the steering rack and some hoses that connect power steering
other than that nothing was mentioned
PS: car is completely stock
      10-28-2016, 10:41 AM   #4
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
Agreed that it doesn't sound like tyres but you could remove any doubt by switching sides. If the fault doesn't move with the change you can rule it out.
      10-28-2016, 10:53 AM   #5
gokudo_90
didn't of doing that,
will try it tomorrow.
but im pretty sure its something with the the Active steering
      10-29-2016, 09:07 AM   #6
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
Sounds like it - there's quite a bit to go wrong there. As you haven't mentioned it I'm assuming that there was nothing definitive, such as a heavy kerb bump, that happened on your track day which might have caused it...
      10-29-2016, 03:43 PM   #7
gokudo_90
not really, i did scratch my wheels on a kerb, but nothing heavy just a usual scratch
but i do notice that every time i park my car on spot that requires riding over a tiny slope( normal house parking) i hear a click in the steering wheel or suspension, not sure where the sound comes from
      10-30-2016, 11:23 AM   #8
doug_999
doug_999's Avatar
2542
I can tell you that a friend of mine had the same issue with his 545 back in 2005. I think it was some sort of programming issue? I'll see if he remembers.
      10-31-2016, 08:43 PM   #9
hsbob
Drives: bme 650 xi grand coupe
turn the car on [motor running] ant then turn the wheel from lock to lock. this calibrates the steering.
