      03-05-2013, 09:22 AM   #1
UCFJWH
Drives: Audi S5
Refueling
I seem to keep having issues during refueling where the handle clicks off as if the tank is full. during a 3/4 tank fill up it will click off at least 15 times and I have to keep restarting it. The thought of just putting the little latch on is impossible because it will not go more than 2 gallons without clicking off.
Am I the only one experiencing this?
      03-05-2013, 11:59 AM   #2
M6Doc
Drives: 2013 M6 coupe
Same thing happens to me all of the time. Sounds like an issue that a lot of people are experiencing, and not just M6 owners. Didn't get much help after taking mine to the dealership.
      03-05-2013, 03:32 PM   #3
jettie1767
Drives: '23 BMW i7 xdrive60
Dealership will tell you that it is a problem with the gas pump. I tried.
      03-05-2013, 04:39 PM   #4
M_Power_Fan
M_Power_Fan's Avatar
Germany
10
Drives: the Ring
i have the same with wife's Audi Q7 V8 and my BMW 120d. Pulling the handle out just a little always helps for me...
hightech in the year 2013...
      03-10-2013, 07:16 PM   #5
Spencer25
2015 M4 Coupe, Black Sapphire
Drives: 2013 F13 M6; 2015 F25 M4 Demo
I'm having the same problem with my 2013 M6. It gets really annoying clicking the pumping and off. How do you think BMW can fix this?
      03-10-2013, 10:21 PM   #6
xDrive35i
xDrive35i's Avatar
Drives: Porsche Macan S
It happens with a lot of cars. The pumps have vacuum pressure sensors that can detect when the placement of the pump is creating suction. If this happens, lifting the pump out slightly will allow you to continue fueling.
      03-10-2013, 11:30 PM   #7
southern6er22
Southern6er22
Drives: 2012 650i xDrive M Sport Coupe
I've found that it only happens with certain pumps - to both my F13 650xi and Denali. I just use certain pumps at my usual stations and I don't run into the problem. This is a pretty widespread problem - several threads about it in the F12/13 6er forum alone.
      03-11-2013, 02:06 PM   #8
DASF13
Drives: 2013 M6 Coupe
I have had the same issue with my M6 and have found somewhat of a solution that you are going to need to play around with in order to get it to work properly.
When I first had this problem I realized that when you insert the pump into the vehicle, you initially get a certain amount of suction, however, even the slightest movement of the handle, or loss of suction, the sensor kicks in and stops the flow of gasoline.
In order to stop this from happening you have to play around with the angle that you insert the pump into your car, and provide a little bit of support with your hand on the underside of the handle.
My vehicle is currently in for service right now, when I get it back I will try and get some pictures of what I am talking about as this might seem confusing to some.
      03-11-2013, 02:29 PM   #9
UCFJWH
Drives: Audi S5
Thanks DAS. I have also noticed that if I hold the nozzle against the top of the port, it works a little better.
      03-12-2013, 05:23 PM   #10
RussianVodka
Drives: 2013 650i GC
Having the same issue with my 650i GC
      03-13-2013, 12:50 PM   #11
jettie1767
If you frequent the same gas stations, just avoid the pumps that cause this problem. You will waste your time bringing it to the dealer as they will only tell you it's a gas pump problem.
      03-13-2013, 02:55 PM   #12
southern6er22
Southern6er22
+1.
