04-28-2015, 09:00 AM | #1 |
Rep 221
whats the widest wheel setting for 20s on m6?
hey guys, im looking to switch my rear tires to wider setting, the front tires on my car are almost gone, but the rear tires seem to be holding up strong.
could i switch to 295/30/20 in the front (current rear tires) and whats the widest i can go in the back without rubbing? i do have spacers 10mm in the back and 5mm in the front. sharif |
04-28-2015, 09:14 AM | #2 | |
Rep 6,072
M6 343M is 0.5" wider both front and rear so you can go up to 285 front 305 rear (my current setup on rear)
04-28-2015, 09:14 AM | #3 |
Rep 19
Drives: 2014 M6 GC
When considering + sizing wheels or changing tire sizes I always start with a decent wheel/tire size calculator. Something like this:
http://www.rimsntires.com/specspro.jsp In addition to recommendations from those who have experience with actually trying out different sizes. My .02 |
04-28-2015, 09:20 AM | #4 |
Rep 221
thank bro, so 315 and 325 in the rear is not doable?
04-28-2015, 09:39 AM | #5 |
Rep 6,072
Not with your current rims. For 315/25/20 you need at least 10.5" width and for 325/25/20 you need 11.5"
04-28-2015, 09:51 AM | #6 |
Rep 427
Drives: 2019 M5 Competition
How wide of rims could you run on the front without issues? Crazy talk, but could you (on the M6) move the rear 10.5" rims to the front, with some spacers, and throw 12" rims on the rear and run something like 305s in the front and 325/335 in the rear? Or is that a terrible idea for 100 reasons?
04-28-2015, 10:44 AM | #7 | |
Rep 6,072
They have different ET. In case of M6, the front is 31 and the rear is 19 Using the link in post#3 the rear rims with 305 tires installed up front stands 0.3" deeper inside and 1.3" outside. 0.3" inside is not a big deal but 1.3" outside is about 33 mm. It's like you use 33 mm spacer on the stock front wheel. Almost the similar thing on rear. Even if you don't experience rubbing (which I doubt), having 4cm wider tire up front (and rear), will change everything as far as steering feeling and handling. Your car will turn to be a bus at corners
04-28-2015, 10:46 AM | #8 |
Rep 68
I'm running 325s on a 21x12 rear, and that's the absolute farthest I would go without being concerned about rubbing big time.
http://i154.photobucket.com/albums/s...pskqsrt4bu.jpg http://i154.photobucket.com/albums/s...psyvn3jvab.jpg Best, Ben |
04-28-2015, 10:57 AM | #10 |
Rep 427
That's what I figured Thanks!
05-13-2015, 03:35 AM | #11 | |
Rep 152
Does anyone know if there is any downside to rolling the fenders? |
05-15-2015, 05:50 PM | #12 |
mrainv23
30
Rep 224
Just put on 15mm spacers from sonic tuning. Perfectly flush with a +25 offset wheel.
2014 BMW M6 Gran Coupe F06/M Performance Black Grille/20% Tint/ Exec Package/ Driver Assist Plus/ Black on Black
Sold-BMW 550i F10/Dinan S3/ Eisenmann Race Exhaust/ Vossen CV3s |
05-15-2015, 05:52 PM | #13 |
mrainv23
30
Rep 224
Close up: I am also running 305s on 10.5 wheel.
11-11-2015, 08:11 PM | #14 |
Rep 146
01-02-2016, 05:38 PM | #16 | |
mrainv23
30
Rep 224
01-04-2016, 12:51 AM | #17 | |
Rep 1,299
Drives: 2015 BMW i8
H&R Springs 21" ADV.1 ADVNL2 MV2 CS Wheels Coming Soon: 2016 BMW M4 GTS De-Winged and Bagged on 22s |
01-07-2016, 04:56 PM | #18 |
463
Rep 2,587
We just built a few 20x9.5 and 20x10 front and 20x11.5 and 20x12 wheels for different BMW M6 applications. Tires varied from 315 rear to 325 rear.
01-07-2016, 06:27 PM | #19 |
Rep 19
and 21x10.5 ;-) front 285 (its maxed)
also 21x12 rear 325 (wheel could probably be .5 wider but no 335 is available) thanks again Robert! use this https://www.rimsntires.com/specspro.jsp |
01-17-2016, 12:19 AM | #20 |
Rep 1,300
Size on 10.5" depends on what tire make/model
The Toyo R888 you can do 315/30/20 on the rear. The 10.5 is within their spec. I have these sitting in my garage and can't wait for winter to be over!! |
01-17-2016, 12:23 AM | #21 |
Rep 14,521
very nice!
09-02-2016, 01:13 AM | #22 | |
Rep 82
