03-24-2015, 09:46 PM | #1 |
Rep 567
20x11 et 20
I have a 2013 650xi Gran Coupe M-sport and bought some rims are the rear are the size listed in the topic. I've seen one other chap on here who had this and he ran 285/30/20 in the rear. Can I get away with 295's?
anyone know? |
03-24-2015, 10:20 PM | #2 | |
MBACPA
13
Rep 91
http://www.rimsntires.com/specspro.jsp |
03-24-2015, 11:48 PM | #3 |
Rep 6,070
There are many things you have to consider...total diameter of wheel, width of tire, offset,...
On 11" rim you can install a tire as wide as 315, but again you need to know all other measurements...
03-25-2015, 10:21 AM | #5 |
Rep 6,070
One measurement is wheel diameter. You can calculate the wheel diameter based on your tire size.
The first number is tire's width in mm. The second number is wall height aspect ratio. The third number is rim diameter in inch. For example the wheel diameter of 295/30/20 = 295 mm + 2*0.3*295 mm+ 20" = 26.968" which is 0.472" larger than your current tire (275/30/20) with 26.496" diameter. Another measurement is offset. I believe the original M Sport package rim (373) is ET 44 and 9" wide . Your new rim is ET 20 while your rim is 11" . Following the link jwblack750 posted, both setup have almost the same Backspace (172 mm vs 173 mm); however the new setup is slightly taller so you might experience some rubbing inside the tire if it touch the housing especially when you have passenger on back seat. On the other hand are expecting more aggressive look since you will have wider track (34 mm each side). FYI my rear setup is 305/30/20 and rim is 20X10.5" ET 19 with no issue but my car is M6... I have no idea about 650i setup. I recall months ago a member here had installed M6 wheels on his 650i GC and he mentioned the same rubbing; however he said it’s not too much. Overall I don’t see major issue with this setup specially like I said your new setup is very similar to M6
03-25-2015, 12:57 PM | #6 | |
Rep 592
03-25-2015, 05:55 PM | #7 |
Rep 567
http://www.6post.com/forums/showthre...ighlight=20x11
Looks like this guy is running 285/30/20 with 20x11 et 20. He states in the thread he would switch to 295's. I've PM'd him with no response. |
03-25-2015, 07:17 PM | #8 | |
Rep 592
Also on a side note, he is most likely using all the negative camber that you can on the 6, and in that case you are going to kill the handling, ride quality, and the tire shoulders will get eaten up every 5k miles. |
03-25-2015, 07:49 PM | #9 |
Rep 194
regarding that black car in the link, as far as i can tell from the pictures, the offset looks mostly ok. If you lower it like he did and put people in the back, rubbing looks doesn't look highly probable except on big dips on his current setup.
but make that 295 and it looks like rubbing. my last car rubbed all the time...hate hate hate hate f'ing hate that issue now after i burned through multiple tires |
03-25-2015, 09:05 PM | #11 |
Rep 592
04-01-2015, 12:46 PM | #13 |
Rep 592
There are tricks for getting it to work like pulling in negative camber to max, also an ET40 would be better but yeah I don't think a 20x11 is going to fit well on anything but the M.
04-01-2015, 01:02 PM | #14 | |
big pimpin
38
Rep 327
2014 //M6 GC
2015 750Li 2015 435i GC |
04-01-2015, 03:38 PM | #15 |
Rep 324
Drives: 2014. 640 ix Vert
04-09-2015, 01:36 PM | #17 | |
Rep 152
All kidding aside, that look on a truck I can understand. On a Bimmer |
04-16-2015, 01:28 PM | #18 |
Rep 2
On my 2015 640 GC I have 20 X 8.5 ET 30 on the front, and 20 X 10 ET40 on the rear. 255 35 20 front ad 295 30 20 Michelin Pilot Super Sports, front and rear. No issues after 500 miles. The rears are pretty aggressive, and I wouldn't think any offset less than 40 might be a problem.
