02-15-2024, 07:39 PM | #23 |
Rep 8
I’ve got the OEM red. Don’t be afraid of coding, it can unlock a bunch of other cool features if you choose to. Also, with Carly, it serves as a scanner as well, not that I have codes but if I do I don’t have to wait to find out what’s wrong. Not sure if beamercode does the same. Being that these are LED’s replacing bulbs it might require coding on some vehicles being that the car is checking for bulbs using a particular voltage that the LED’s won’t respond back to the system & can throw a fault code. I initially didn’t code my car & had no codes. I eventually coded for the LED’s because I also coded to have the taillights on with the DRL’s(daytime running lights) that way the light is on at all times. Also, get a wire/cable fishing kit to run the wiring through the trunk posts for proper wire management with the trunk opening & closing, fishing from top to bottom was easier for me
Madison5116.00 |
02-15-2024, 08:22 PM | #24 |
Rep 41
Thank you for your comment and recommendations. I may pull the trigger on these soon. Trying to decide between red or smoke for my black M6 convertible?
Do you have the info/link for Carly you could post to lead me in the right direction? I don’t know what that is ha ha |
02-17-2024, 06:44 PM | #25 | |
Rep 8
Madison5116.00 |
05-14-2024, 08:24 PM | #27 |
Rep 26
Drives: 2008 M3 - 2022 M5 - 2014 M6 -
Anyone hear anything about the fix for the tailights?
Current
2008 M3 - 2014 M6 - 2022 X5 - 2022 M5 - 2022 M8 - 2023 TRX |
Today, 11:14 AM | #29 |
Rep 26
Just emailed that they are trying to get with Carly and Bimmercode as it is a coding issue in the North American cars. They are attempting to adapt coding to not initiate the turn signals and the brake lights at the same time which would effectively resolve the issue. Anyone overseas want to buy mine? Tired of waiting for something that could have easily been rectified for the NA market before production.
Current
