      02-13-2015, 12:18 PM   #45
vladberca
vladberca's Avatar
Romania
763
Drives: '18 octavia 2.0 tdi dsg
I think it's a smart move to offer an x-drive model with high performances near M6 GC!
Of course there are some good points (like better traction), and a weak point with more weight. A comparative test should be very interesting!
      02-14-2015, 10:04 AM   #46
doug_999
doug_999's Avatar
2543
Originally Posted by JimM6GC View Post
Yep. I'm sure glad the dealers that had B6's in the showroom when we wanted to buy one last December were either jerks or so enamored with the cars that they didn't want to part with them. We were willing to hold our position and simply wait for the LCI version, and the added HP and torque makes us extremely thankful that we did.
Assuming the dealer we agreed to go with doesn't pull the added-dealer-markup BS and doesn't have production slot problems, we should have one on order as soon as we can. I promise to comment on a comparison between our M6GC with the B6 if all goes well.
Yep, I was thinking about you when I posted this. You need to go thank those dealers for being complete A$$es
I also find it interesting that so many people consider DCT such a huge benefit. Yes, it snaps off the shifts faster, but stop and go performance suffers -or at least it has in all of those that I have driven.
      02-14-2015, 12:08 PM   #47
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
doug, DCT has different configurations and based on those configurations has different characters. The most aggressive setting is S3/D3 while throttle is set in sport+ while the softest (D1/S1 with efficient throttle) is really soft and comfort, but not as smooth as ZF8 because of clutch instead of torque converter... To me DCT is a huge benefit and reminds me over 20 years manual tranny experience with the advantage of fast shifting, but as you know I'm biased to "love M6" ...
I think this post has explained the difference very well...
Originally Posted by Needsdecaf View Post
A few things that are different.
Some of the posters above are steering you off track. I mentioned the torque converter not because it's the only way to get smooth take offs, but because of HOW IT WORKS. A torque converter uses two "fans" essentially, spinning in fluid (ATF). Very simply put, the "fan" on the engine side spins as the engine speeds up. At first, nothing happens. But as the "fan" spins faster, the fluid's shear eventually starts to transmit force to the other "fan" and the wheels receive power. This is very gradual and soft, hence "smooth starts". At some point, the two sides will lock together using a clutch, and you will have no loss due to the heat in the fluid.
Because the DCT has no torque converter, it uses a clutch to engage the drive side (engine) to the driven side (wheels) (two actually, one for odd gears, the other for even). So it's engagement behaves the same way that a manual transmission would. Here is the difference.
In a traditional manual transmission, the driver is in charge of two things, throttle and clutch. You choose how many revs to add, and how quickly or gradually to engage the clutch. You control the smoothness of the engagement.
In the DCT, you still control the throttle, but the computer controls the clutch. It needs to guess your intentions based on throttle input. So, if it senses you rolling into the throttle, it'll engage the clutch slowly. Jam into the throttle, and it'll slam the clutches shut, expecting that you'll want a fast takeoff.
So the trick is that you need to work simpatico with the computer that's engaging the clutch. Since there is no fluid filled torque converter damping out any differences, you're going to feel when you and the computer are at odds with one another.
I won't get into shifting underway, as that's usually not as much of an issue.
Hope this helps.
      02-14-2015, 12:24 PM   #48
doug_999
doug_999's Avatar
2543
Yea, I totally agree -from a performance standpoint, the shifts bang off with precision. But what drives me nuts (literally? ) when driving the DCT is that the computer is letting out the clutch for me on take-off. So there is that lag between pressing the gas and then the trans saying "ohhh, you are ready to go? ok then". I think it might depend on the type of driving one does. For my stop and go here in the Chicago area, test driving the S6 as well as the M3 both made me wish for a manual or the 8 speed auto.
      02-14-2015, 12:46 PM   #49
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
I see your point. You can almost eliminate that lag (from stop) by setting the throttle in Sport+ and MDM and S3/D3 (for rolling), but then it's jerky and not smooth for stop and go, since car wants to jump hard....
      02-22-2015, 12:10 PM   #50
JimM6GC
Drives: '15 M6 GC; '16 B6
Dealer says they have production numbers for the B6's, but they don't yet have pricing/ordering guides available. They said that I can order one now using the '15 ordering guide.
Anybody come across the pricing/ordering guides for the '16's yet? Supposedly SOP is 3/15 along with the other 6ers, so I am surprised the ordering guide isn't available yet. Doug - I know you posted one last year, and that's what we will use to place our order. What do your sources say?
      02-22-2015, 12:25 PM   #51
doug_999
doug_999's Avatar
2543
I will ask!
      02-24-2015, 12:17 PM   #52
doug_999
doug_999's Avatar
2543
Everything is out EXCEPT the Alpina!
Weird.
I would make sure you can change the order once the guide comes out. Because nothing would be worse than a new option you really want.
      02-26-2015, 12:54 AM   #53
JimM6GC
Thanks, Doug.
We just got back from a whirlwind trip to the L.A. area to prove that we were serious. I am not sure what their alleged "production number" is really for. Nothing says it is for a '16, and I could not get any information from the 1-800 number that I used to check production status when I ordered my M6GC. I understand that production has not yet started, but I expected to see some kind of tie to the '16 models. Fortunately, all of our email correspondence is clear that we want to order a '16. I will give them the benefit of the doubt at this point, but I am wondering if the number is just a place holder within the dealership. We'll see.
And yeah, we don't want to fully commit until we see what the actual ordering guide looks like.
      03-03-2015, 12:35 PM   #54
doug_999
doug_999's Avatar
2543
Order Guide
Jim
Here you go. My dealer reports all but 4 build slots are taken! And residuals are down a percent from the 2015s.
File Type: pdf 2016 BMW ALPINA B6 GC Rel 2015-02-27 - OrderingGuide.pdf (71.7 KB, 619 views)
      03-04-2015, 12:15 AM   #55
JimM6GC
Thanks, Doug!
I guess I'm not too surprised that the production slots have filled up so fast. The added HP and torque numbers were somewhat of a pleasant surprise to us. Any pricing info out yet?
I see that they have a new color (among others) available - Mediterranean Blue. We were going to order Alpina Blue, but I took the Alpina Blue paint code to an automobile paint dealer and got a pint of the stuff. After priming, spraying, and cleat-coating a sample, well, its ... purple. Not a bad color, bit not really our style. Further proof that one should not base one's color choice on what one sees in a not-too-well-lit showroom (Irvine BMW). We will be looking at an example of Tanzanite Blue at a dealership in the SF Bay Area this weekend, and we already ruled out Deep Sea Blue (which has been deleted, and which doesn't look too much different from Mediterranean Blue from the pics I've seen), so it will be interesting to see what our final choice is. So far, it's Mineral White, even though we're somewhat tired of the white/silver/grey routine of our past cars.
We "buy and hold" our vehicles for several years, so residual value is not a big concern to us. However, I am wondering if they have factored in the possibility that leases will expire at about the time when the G series cars will be coming out.
It will be interesting to see where we are in the production queue. Since we got a discount on the car, we may be one of the last ones in line at our dealership. RichardP - do you have any production stats (cars per month) for the US market for these cars? If we end up being at the tail end, we may just wait another year.
      03-04-2015, 08:28 AM   #56
doug_999
doug_999's Avatar
2543
To be clear, it is the first round of production - not total. And in that, per my dealer "Currently 34 order slots available in the US….only 7 of which are not sold….and 3 of those are in 'Center Own Use' status which means don't call me you can't have it!"
As for the blues...
I think "Alpina Blue" is the standard blue you see on most Alpina's that aren't black. It is a cool color and screams "This is an Alpina". I wouldn't mind it of course, but I think the Mediterranean is a darker blue and would be even sweeter. Tanzanite is STUNNING in person and if you can get that for only an $1,800 up charge, then do it!
You are getting a special car, get a special color - that's my advice
edit: re the lower residuals, BMWs normally have a lower residual at the beginning of the model year production than at the end. I expect it will go up a bit.
      03-04-2015, 11:40 PM   #57
JimM6GC
*Whew!* Thanks for the clarification, Doug.
I called the 800 number with our vehicle production number, and I learned that our vehicle is "scheduled for production with no confirmed production date." I assume that could be status code 112 and that we at least made it to the first round of production, even though the production week ordinarily is assigned at status code 87. I have read of other people with status code 112 with no confirmed production date for non-Alpina cars, so perhaps that is the correct status code. I guess a call to the dealer is in order.
I've seen some of the photos of Tanzanite Blue cars posted by other members here. It sure looks intriguing. If all goes well, we will get to see a TB 650i this weekend at a SF area dealership. Supposedly there are at least two in the area.
      03-05-2015, 07:44 AM   #58
doug_999
doug_999's Avatar
2543
Here is your pricing guide
Pricing guide
      03-06-2015, 01:53 AM   #59
JimM6GC
Pricing guide
Thanks again, Doug!
You rule!!
Jim
      03-07-2015, 02:13 AM   #60
JimM6GC
Our order has a status code of 111 as of 3/3/15, so at least it was accepted at BMW AG.
The VIR lists an "Ind. Block Date" of 3/30/15. Anybody know what that means?
      04-08-2015, 01:23 AM   #61
JimM6GC
Week 18 production week.
Anybody else pull the trigger on one of these?
      04-08-2015, 06:04 AM   #62
doug_999
doug_999's Avatar
2543
So what does that make the eta to your dealer?
      04-09-2015, 01:57 AM   #63
JimM6GC
I don't know for sure. If my experience with the M6GC is any guide, I suspect the car will arrive sometime in early to middle July. That takes into account the facts that B6's take an extra two weeks to build and that the car must wait for a ship, float across the Atlantic, cross the Panama Canal, and make it up to Port Hueneme, CA.
I'm just happy that the order apparently did make it into the first round of production that you mentioned previously.
      04-09-2015, 09:48 AM   #64
spuntyb
spuntyb's Avatar
Drives: 2019 F90 Competition
Drove behind a black B6 GC on the west side highway yesterday afternoon. NJ plates. Don't see too many of these in the wild, so wondered who it might be - forum member maybe? Beautiful ride!
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold)
2018 F80 ZCP TB|SS (sold)
2015 F30 335 AW|CR (sold)
2015 F31 MG|CR (sold)
2011 E90 JB|Oyster (sold)
      04-11-2015, 10:45 AM   #65
dsad1
Drives: car
Anyone getting any discounts on the B6? I am looking to use the pull ahead program to get out of my 650 into a B6. Curious as to what people are purchasing them for before I got to my dealer.
      04-11-2015, 11:15 AM   #66
doug_999
doug_999's Avatar
2543
You should be able to get a decent deal on the 2015s. I would contact Brett Midgley if you are interested in shipping one at a great deal
http://www.bmwautohaus.com/new/BMW/2...66e9f3ad9e.htm
brett.midgley@bmwautohaus.com
