09-12-2022, 10:48 AM | #1 |
Rep 591
Best Explanation for BMW Break-In Service I've Seen
Featured on BIMMERPOST.com
?18 M4 Comp
17
///MPhatic13904.00 overcoil3075.50 jmg18721.00 Entropy89196.00 Rocky_M22.50 ppointer743.00 T0RM3NT3654.00 M3 boi3211.00 Mr.blue223.00 russell21147.00 Djhawkg796.00 TractionControlDelete4594.50 Seattlesquash905.00 gnx759.50 SimsimmaM3172.00 2srsman68.00 Niko ZV118.00 |
09-13-2022, 06:02 PM | #3 |
Rep 92
Been SOP in the racing world for many years. You run a "break-in oil" that is thinner than the regularone. Drive the car under controlled circumstances and it helps shave down all rough parts, seal gaskets and bearings, and go through multiple heat cycles letting the driveline get all settled in. They you flush it, refill it with the correct weight, and let 'er rip!
Rides--
'17 M3 CP-CAI, Dinan Stg 1 '17 Camaro ZL1 (700HP) '15 Audi S4 (500 HP) '15 Charger Hellcat (1050 HP) |
15
10-25-2022, 01:03 PM | #6 |
Rep 239
Drives: '17 M240i 6MT
Anything brand new with spinning metal components will wear down the rough edges under initial use. For that reason, I'd also suggest transmission fluid and transfer case if applicable. Do not flush the transmission fully, just let it drain (for the auto).
2017 BMW M240i 6MT Slicktop | Wavetrac 3.46:1 Limited-Slip Diff - DinanTRONICS Sport Boost Controller - H&R Sport Springs - Millway Street Camber Plates - Agency Power Intake w/ Paradigm Engineering Turbo Inlet
russell21147.00 |
10-25-2022, 01:07 PM | #7 | |
Rep 865
2023 i4 eDrive40
2022 Acura MDX |
10-25-2022, 01:08 PM | #8 |
Rep 239
Anyone had issues getting the service done on their g80. Dealer says that diff fluid is not available and don't have an eta. BMW is saying there is a global shortage.
Current - 2020 G20 M340i Mineral White/Cognac
Past - 2016 F22 M235i Dinan S3, 2009 E92 M3, 2010 Nissan 370Z, 2004 E46 330i, 2003 E46 325i, 1999 E46 323i |
lexae5.00 |
10-25-2022, 01:09 PM | #9 |
Rep 3,261
My car told me service needed at 1200 miles. started annoying my at like 400 miles.
2022 BSM/FR M4 Competition X-Drive 2017 MW/SO M4 ZCP [SOLD] • 2015 MW/SO M4 M-DCT FBO [SOLD] • 2011 AW/CR 335is DCT FBO [SOLD] • 2008 AW/CR 335i 6MT FBO [SOLD] |
10-25-2022, 01:48 PM | #11 |
Get off my lawn
932
Rep 1,159
Drives: 6MT
Garage List 2023 GR Corolla [0.00]
2022 BMW X3 M40i [10.00] 2007 BMW Z4M Coupe [0.00] 2002 BMW 325xiT [0.00] 1991 BMW 318is [0.00] |
Completed the service on my own dime at 1,200 miles. Fluids are cheap preventative maintenance
SpencerC_6MT197.00 StradaRedlands4950.50 |
10-25-2022, 01:49 PM | #12 | ||
Rep 353
BMW won't CPO a car that hasn't been run in properly…e.g. near the 1200.
Dont be humble, give me that rumble. 2022 F95 X5MC, 2020 G05 40i, 2016 F86 X6M (sold), 2014 328ix F30 (totaled), 2009 e91 328ix (sold), 1997 740i e38 (nikasil fail)
10-25-2022, 01:50 PM | #13 | |||
Rep 865
2023 i4 eDrive40
2022 Acura MDX |
thaalrasha621.00 330iToy71.00 |
10-25-2022, 01:54 PM | #14 |
Rep 70
There shouldn't be any rough parts in an M Engine, these are ultra precision made pieces of equipment, the purpose of a running in oil is that it is mineral based with zero additives, it is these additives (found in semi synthetic and fully synthetic oils) that are designed to prevent wear which you don't want in a running in (mineral) oil as this prevents the engine from bedding in properly. If you ran fully synthetic from the get go you'd end up with an engine that won't bed in properly resulting in poor piston ring sealing and increased blow by resulting in oil burn and power losses.
10-25-2022, 02:07 PM | #15 |
Rep 2,007
Drives: 2022 i4 M50
Correct... only M cars that require it.
Not a bad practice to do an extra one anyway if you plan to keep the car long-term. I had an the oil and diff flushed a second time at 1200 miles in my F92 because they did the break-in service at 300 miles (it was already a year old). I paid out of pocket to have it done because my SA couldn't put it through the maintenance place, but I ended up having BMWNA thanking (reimbursing) me for it. I would have done it myself in my new m-lite-ish car if I could.
Current: 2022 i4 M50 | 2022 G07 X7
Gone: 2020 F92 M8 | 2020 G07 X7 | 2018 F80 M3 | 2017 F15 X5 | 2016 F16 X6 | 2015 F36 4 series GC |
10-25-2022, 02:08 PM | #16 |
Rep 1,098
Drives: '01 Z3M, '12 335is, '22 540i
Garage List 2012 BMW 335i [5.25]
2012 BMW 335is [5.00] 2008 Infiniti QX56 [0.00] 1967 Chevrolet Corv ... [10.00] 2001 M Roadster [10.00] 2022 BMW 540i [0.75] 2009 528i [9.50] |
10-25-2022, 02:15 PM | #17 |
Rep 206
Drives: 2015 BMW X5 50i
"Homeboy" got lucky on his engine replacement. Wish BMW hadn't warrantied it for him just because he was such an idiot.
Great information in this video though! Definitely worth the watch past the ~4 minute mark
2015 X5 50i - Current
2011 E92 M3 - Sold 2016 F30 340i - Sold |
10-25-2022, 02:17 PM | #18 |
Rep 4,164
ok i'll book it in!
10-25-2022, 02:24 PM | #19 |
Flavor of the month
903
Rep 720
Drives: BMW F87 M2C
Another day, another break in procedure thread.
For the record, you are all wrong and my way is the best way. Been doing it for yada yada yada.
Samuel of the Internet
2023 F98 X4M Comp 2023 F95 X5M Comp 2020 F87 M2 Comp |
10-25-2022, 03:12 PM | #20 | ||||
Rep 353
Djhawkg796.00 Westside Guy5747.50 |
10-25-2022, 03:34 PM | #21 |
Rep 29
Good video.. In the g8x m3/4 Facebook group some of those guys ignore this and rip their cars at around a few hundred mile break in. They were also trolling others for following the recommended break in from BMW M division which, to me, sounds ridiculous not to follow the engineers lol.
10-25-2022, 03:35 PM | #22 |
Rep 395
Drives: 2018 M550i Xdrive, 2021 X5M co
Some of the information is obvious but I would say that this is a great informational video. It will hopefully quiet some of the naysayers and nonbelievers that say otherwise. Again, great video.
Mike
