      08-08-2017, 09:22 PM   #1
Mnite_S63
Drives: 2013 F13 M6, 2010 X5M
Eisenmann Race Exhaust Owners Help
Hello all,
Just got my Eisenmann Race Exhaust installed. Sounds great but I am getting heavy vibration on Cold Starts. Vibration is obvious as I can see my rear view mirror vibrate. Once it drops the RPM all is good.
You guys have the same issue? Is it norma? Only on cold starts.
Thanks
      08-09-2017, 04:36 PM   #2
BMWDriverX
Drives: G12 750i X-Drive
It's normal. Sounds like something inside your car is vibrating due to the new exhaust not being as muffled as the OEM one was. I would try to pin point whatever is now vibrating and you can usually use some silicone glue to buffer between the two surfaces vibrating or even a folded piece of paper if you can hide it out of view will do the trick.
