06-23-2019, 11:27 AM | #1 |
Mid life crisis
28
Rep 68
Drives: 2012 650i Convertible F12
Speedo 2 mph slow. How to fix?
2 separate GPS systems record my actual speed (55-85 mph range) as 2 mph slower than: speedo, cruise setting, HUD, and dash computer.
I haven’t tried to compare anything under freeway speed. Car has original 20” 2H9 package and Dunlop stiff walls, so I don’t think it’s anything to do with tire circumference. Not a big deal, I just adjust my speed to WAZE or GPS device speed for a long cruise, but I’m guessing there’s a worn part (used to be plastic worm screws in analog cars) that can be replaced or adjusted. Thanks
langnasiger silberner Bayerischer Hai
06-23-2019, 12:48 PM | #2 |
Rep 7,489
Are you new to BMWs? I only ask because this issue (speedo not truly accurate) has been a discussion that I've seen/read about since I've known/owned BMWs (the mid 1980s). I long ago wrote this off as a non-issue...recognizing that my speedo is actually a mile or two below what I'm actually seeing on the instrument cluster. And set my speed accordingly especially if on a long highway trip and using cruise control. Driving around town...I rarely even think about it unless a see the police on ticket patrol...then I know I have a built in "cushion" of a couple of MPH when I glance down to see how fast I'm going.
Flying Ace4984.50 |
06-23-2019, 01:19 PM | #3 | |
Mad Fiddler
792
Rep 994
Speedo error
06-23-2019, 01:28 PM | #4 | |
Rep 7,489
And I believe the difference between the odometer and speedometer is handled electronically as well. We know (based on tech data from the e38/e39/e46/e53 era) that distance data was sent to the ABS unit, then onto the IKE (instrument cluster electronics) by way of the left rear wheel sensor. So somewhere in the mix, the mileage is being recorded...but the speedo is knocking off MPH based on some type of algorithm. So actual mileage is correct although speed/MPH is being slightly reduced as it appears in the speedometer. EDIT: Here's some old data I had for the e38/e39/e46/e53 generation...see DISTANCE SIGNAL for the correct interpretation of what I was trying to write above. I bet if one searched the TIS for the new generation BMWs...you will probably find similar design parameters/elements:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 06-23-2019 at 01:34 PM.. |
Frupal791.50 |
06-23-2019, 01:55 PM | #5 |
Rep 659
there was a secret menu on the 5 that could eleviate this, accomodating the different sizes of factory alloys
correct factor from memory
Current: 2017 M6 Gran Coupe
06-23-2019, 02:29 PM | #6 | |
Rep 7,489
The hidden cluster tests are great for accessing operating data/parameters of the instrument cluster electronics...but usually most of the tests only allow you to observe and not manipulate the data/info. I noticed in the video you linked...TEST 10 would probably be the test for speedo information...but unfortunately the data is "grayed-out" (which usually means you can only observe the data...not change it). If you can change/manipulate the data or access more info...the TEST's text is usually white. So I'm not sure if this is a way to make any changes. Note all the data for TEST 10 is gray...not white. And I have used the hidden test on my e39 540iT to correct the fuel consumption factor to bring the OBC into proportion with the fuel consumption I was calculating in an Excel file.
06-23-2019, 02:36 PM | #7 |
Mid life crisis
28
Rep 68
I remember “Road & Track” would always note Speedo error on their new car road tests (analog days, when fuel injection was waaay out there).
With everything digital now, you’d think a 2.5% error would be grounds to fire the engineers and sub the work out to HAL 9000.
06-23-2019, 02:57 PM | #8 | |
Rep 7,489
Frupal791.50 |
06-23-2019, 05:44 PM | #9 | |
Mad Fiddler
792
Rep 994
06-23-2019, 08:40 PM | #10 | ||
Mid life crisis
28
Rep 68
06-24-2019, 06:44 PM | #11 |
Rep 998
I've had this problem on 4/4 bmw's I've owned. Super annoying considering the speedometers on most other cars I've owned have been almost dead accurate +/- 1 mph.
