01-27-2024, 01:56 PM | #177 | |||
Rep 167
Anyway...6 Fam!! I'm so stoked that we should have our lights in a couple weeks! Just so you know these are all still prototypes. Factory production light internals will be frosted and you won't be able to see the LED dots. What a journey this has been for all of us but especially for me trying to bring these into the world lol. We made it happen tho and I appreciate you all for your interest and support. The power of community! Last edited by BMWisBest; 01-27-2024 at 02:12 PM.. |
02-14-2024, 11:38 PM | #179 |
Rep 26
Drives: 2008 M3 - 2022 M5 - 2014 M6 -
Installed mine a few days ago - Start up configuration is pretty cool. Fit and finish is good. Had to code to LED tails but I was looking for an excuse to get bimmercode anyway. Only issue I am having is that when the brake lights illuminate (red), the turn signals also illuminate (amber). If the turns were red, really wouldn't be an issue but since they are amber, kind of looks like a mistake. Thinking it may also be illegal where I'm at as brake lights have to be red. I have an email into Bavgruppe to see if there is coding that can remedy this or if it was intentional for some reason. Kind of reminds me of a Hooptie with and electrical problem.
02-15-2024, 10:14 AM | #180 |
Rep 26
Answer from Bavgruppe:
"We’ve noticed some of the cars have this, it seems to be a small surge in voltage that is triggering the signals as they work off of the same wire as the brakes. We’re going to be making an adapter plug and send it out to those that have experienced this. I think we will be done with it within the next two weeks." I'll give them a few weeks for a solution, but the reasoning does not make complete sense.
Current
2008 M3 - 2014 M6 - 2022 X5 - 2022 M5 - 2022 M8 - 2023 TRX |
dolfan4009.00 |
03-04-2024, 05:04 PM | #181 |
Rep 4
Can anybody chime in that has had success with these being plug and play? Anything to do with pre-LCI vs LCI? Also did you guys receive an error code right away after install that lead you to have to code them? Thanks in advance for the help.
Madison5116.00 |
03-19-2024, 09:26 AM | #182 |
Rep 26
Is there a member that has had these work with just coding or do we all have the issue with the turn signal/brake lights?
Current
Madison5116.00 |
04-05-2024, 11:57 PM | #184 |
Rep 167
Fcs1965 Volley96 ruflife
So I spoke with Tom from Bavgruppe. Apparently we have a unique feature on our cars that they didn't predict would affect the way that the aftermarket tail lights would function - Our brake light and our indicators actually share the same light. It just blinks when you use your turn signals This is why when you brake with the GTS tails the indicators come on. They're just in a different location on these lights. They are creating an adapter to modify the behavior and it should be ready in a week or two! |
04-10-2024, 08:19 PM | #186 | |
Rep 26
Same thing they told me a month ago. I already had to pull them out to pass safety inspection. Going forward, they should just delete the amber bulbs and make them all red. Wouldn't be an issue or illegal that way in the U.S. Not sure if Europe still requires them to be amber.
Current
04-12-2024, 12:35 PM | #187 |
Rep 281
It seems these lights still have some work to do before they are useable. Ill wait for future generations when they’ve perfected them. They are gorgeous though!
04-12-2024, 02:24 PM | #188 |
Rep 26
from Bavgruppe today:
" Well, yes. We found out during testing that this is actually normal behavior for the tail lights on your vehicle, and on every vehicle based in the United States, and not a taillight defect. All 6 series turn signals double as brake signals, not sure why not a single owner noticed it but we tested a couple of stock vehicles and they did exactly that. Now that we know this, we finished the testing on the vehicles and have a second set of plugs being sent to us, they’ll arrive sometime next week, to accommodate owners wishes to turn off that portion of the stock behavior. We also need to bring a car in to do some testing with ISTA (a coding platform) to see if we can shut off the stock portion of the coding that makes the turn signals turn on, but again, it’s not a defect. We have one of the cars that we use for the initial testing coming in to get a different color set of tail light so we will test the plug on his car and also do the ISTA coding. " I'm guessing the new harness will delete the brake light function from the turn signal portion. Saga continues ...
Current
BMWisBest121.50 |
04-16-2024, 10:50 PM | #189 | |
Rep 11
04-17-2024, 09:19 PM | #190 |
Rep 26
Probably have to contact them to get on the list.
Current
