      10-21-2016, 08:30 PM   #155
jpnh
jpnh's Avatar
1425
Drives: NA
A gun doesnt have to be cleaned every single time you use it....particulary....ESPECIALLY if you regularly use the gun.
A handgun you use regularly or carry (ie depend on) DOES however require proper lubrication ESPECIALLY in the winter
If however you're shooting corrosive ammo then you need to clean that gun more or less immediately after shooting.....I recommend windex down the barrel/in chamber to neutralize the primer salts.....if its not a bolt action gun you'll need to pull apart the entire gas system and clean it too......unless you like rust/useless guns
People do more damage to guns while cleaning than doing anything else with them
      10-21-2016, 08:48 PM   #156
Mr Tonka
is probably out riding.
Mr Tonka's Avatar
Drives: Something Italian
I stopped cleaning every time i shoot a wile ago. Especially with blue collar guns. If i only shoot a gun every now and then, i'll full clean and putt a storage amount of lube on it. Too many gunsmiths told me that full solvent cleaning after every shoot is bad.
That said, take care of your tools and your tools will take care of you.
My post shooting ritual, during a movie or football game, is jamming the mags. I keep most mags loaded so i can just grab and go to the range/farm.
"There is no greater tyranny than that which is perpetrated under the shield of the law and in the name of justice. -Charles de Secondat"
http://www.m3post.com/forums/signaturepics/sigpic59612_1.gif
MKSixer34192.50
      10-21-2016, 09:04 PM   #157
Thxrick
The Cool Guy/ You're drinking' Buddy
Drives: 2009 335 e90, 2015 GTI
Gun porn!
I keep my magazines filled all the time...thank the lord for speed loaders. I enjoy doing it and am sure i will enjoy cleaning them. Similar to wrenching on the car.
      10-21-2016, 09:05 PM   #158
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
I usually have some loaded and rest in boxes for down the road. This doesn't work very well with a beard.
      10-21-2016, 09:42 PM   #159
insanecoder
Drives: 340isDrive
Firearms and bimmers
If you love the gun break it down and clean after each session
Gotta admit gettin a bit lazy too so been seeing just the bore brush recently after each
      10-21-2016, 09:50 PM   #160
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
See I don't see it as lazy, I too don't think it's a good idea to overclean a gun that's routinely used. Keep it lubed up and do it once in a while
jpnh1424.50
Mr Tonka6060.00
      10-21-2016, 10:16 PM   #161
insanecoder
Drives: 340isDrive
Can see yer POV but not chancing any residue corroding any part of my guns but will do breakdown cleaning and oil whenever time allows.. esp in the more humid months
      10-21-2016, 10:38 PM   #162
jpnh
jpnh's Avatar
1425
Drives: NA
You wont get corrosion from fouling from modern ammunition....especially with the coatings that are on modern firearms....and its especially not an issue on anything with a chrome lined barrel or stainless barrel
Accuracy is actually BETTER on firearms with SOME fouling.....HUNDREDS of rounds of fouling will have a negative effect
Mr Tonka6060.00
      10-21-2016, 10:50 PM   #163
insanecoder
Drives: 340isDrive
I buy cheap ammo many from foreign makers cause I shoot alot.. not sure their primers etc so I dont take a chance plus they generally dirtier
      10-21-2016, 10:52 PM   #164
Rogue_fxdl
Rogue_fxdl's Avatar
Drives: '17 M3 / '11 325is/89 325is
just my .02cents, clean it and maintain it like your life depends on it..just like pre flight checks...
"If you see the muzzle flash, your still alive....react"
Me..
      10-21-2016, 10:53 PM   #165
Fundguy1
Fundguy1's Avatar
2036
Drives: 335 e93
I dont full solvent clean each time. I do a bore snake and oil and wipe the rest. The 1911 likes to be wet with oil. The AR hates carbon buildup.
Mr Tonka6060.00
      10-21-2016, 10:54 PM   #166
jpnh
jpnh's Avatar
1425
Drives: NA
Its virtually impossible to find current production ammunition with corrosive primers these days
Anything comm block surplus is definately corrosive
ie anything 7.62x54r, most of the Yugo 7.62x39, most of the 8mm
      10-21-2016, 10:57 PM   #167
Fundguy1
Fundguy1's Avatar
2036
Drives: 335 e93
I do shoot corrosive 8mm in my k98 and do clean thst after almost immediately. I also live in humid florida so keeping everything oiled doesnt hurt.
      10-21-2016, 11:06 PM   #168
insanecoder
Drives: 340isDrive
Ya I shoot Russian and Serbian ammo and suspect theyre corrosive
      10-21-2016, 11:07 PM   #169
Fundguy1
Fundguy1's Avatar
2036
Drives: 335 e93
Mine's Yugo. I know it is.
      10-21-2016, 11:13 PM   #170
Mr Tonka
Mr Tonka's Avatar
I doubt there is a wrong answer here. Most of us don't shoot enough where solvent cleaning after each shoot would be detrimental. And a simple bore snake and shot of lube after each shoot is generally more than enough to keep everything in good working order. You know your gear, take care of it as needed.
As Fundguy pointed out, different weapons like different treatment. You can run a glock dry as a bone for weeks. Do that with most 1911s and you're toast after a few mags.
      10-21-2016, 11:14 PM   #171
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
Just don't get that lacquer crap
      10-21-2016, 11:19 PM   #172
jpnh
jpnh's Avatar
1425
Drives: NA
Dont put it into an AR
Most comm block guns eat it just fine
I'm not a fan of the steel cased/laquer shit myself
      10-21-2016, 11:23 PM   #173
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
Yeah I shoot steel at my outdoor range brass at indoor but only polymer coated not laquer. Seems this part of forum generates a decent amount of interest go figure we got some shooters here.
      10-22-2016, 04:00 AM   #174
someguywithanm3
someguywithanm3's Avatar
319
Drives: E92
Finally, a manly thread.
      10-22-2016, 05:38 AM   #175
Mr Tonka
Mr Tonka's Avatar
We're just a bunch of mindless, neckbeard militia types. Stockpiling weapons of mass destruction at our compounds, waiting for the opportune time to overthrow the gubberment. Until then, we'll be content to terrorize all the peaceful citizens by going to designated shooting ranges to practice the overthrowing skills.
Viva la revolution!
      10-22-2016, 09:11 AM   #176
Thxrick
From what I have been told and read, a lot of guns like the ones I am using (Glock, Sig, etc) can take such a fkn beating and still be ready and operate like a charm. My plan is to clean after every other range session...should be good.
Thanks for all of the info., guys.
