BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
► APEX | ARC-8 Light Weight Track Wheels
08-09-2017, 03:15 PM | #133 |
BimmerPost Supporting Vendor
3571
Rep 6,805
This is what our wheels are made for. Here's a square set of 18x10" ET25s.
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
08-11-2017, 05:02 PM | #134 |
Rep 1,071
I have e92 and drop, wanted to see whats a good tire size setup to go with these:
Apex Arc-8 Front: 18x9.5" ET35 Profile 3 Rear: 18x10.5" ET27 Profile 3 I'm open to other suggestion. I want to basically drop a car just a little bit, and runs as wide as possible , but the lowest rear profile must be 35+,wants more cushion to get better road noise. I'm switching from stance to meaty setup. Currently on BC Coils, 19x9.5 et32 235/35/19 19x11 et25 265/30/19 |
08-15-2017, 01:02 PM | #135 | |
1439
Rep 2,654
Appreciate your interest. The staggered fitment you mentioned is one of the most popular fitments for this chassis, however the front wheels should have a lower offset for a more flush fitment. See below: Front: 18x9.5" ET22 Profile 3 - 265/35-18 Rear: 18x10.5" ET27 Profile 3 - 285/35-18 Revised post: Your current rear wheels are extremely aggressive. I'm assuming you rolled your fenders in the rear, is that correct? Also, how much negative camber do you plan to run going forward? For a meaty tire fitment on a E92 non-M I would typically suggest: Front: 18x9" ET30 - 255/35-18 Rear: 18x9.5" ET35 - 275/35-18 Since you were running an 11" ET25 in the rear previously and likely have rolled rear fenders and a bit of neg camber dialed in, you could go with a more aggressive rear. Note this rear fitment is not a bolt-on solution and would require the modifications mentioned. Front: 18x9" ET30 - 255/35-18 Rear: 18x10" E25 - 275/35-18 - Ryan
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by ApexWheels; 08-17-2017 at 04:16 PM.. |
08-16-2017, 02:23 PM | #137 | |
Roll Tide
591
Rep 2,345
08-16-2017, 03:29 PM | #138 | |
Rep 307
08-17-2017, 04:06 PM | #139 | ||
1439
Rep 2,654
You are correct, I mis-read the gentleman's post and recommended an E9X M3 staggered fitment. The post has since been edited Quote:
A few questions for you: What suspension are you running? This is for heavy track use, correct? You have adjustable camber plates up front, correct? What tire brand do you plan to use? - Ryan
08-17-2017, 10:21 PM | #140 | |
Rep 1,071
My goal is to get higher profile that the reason i'm stepping down to 18". I like the setup you have mention for the rear, but wondering for the Front instead of 35 profile, can I do 40, as: 18x9" ET30 - 245/40-18 Also when will there be another Group-buy? Thank you so much for answering these question. |
08-18-2017, 12:56 PM | #141 | |
Rep 491
08-23-2017, 04:43 PM | #142 | ||
3571
Rep 6,805
As far as the group buy, we don't have any set dates yet, but you'll want to sign up for notifications to stay up to date. You can sign up on our website towards the bottom at www.apexracepats.com. Quote:
With that said, the 18x9" ET30 is a great Profile 3 square setup for E92 non-M cars, and is our most recommended setup. You can pair that with 255/35-18 tires all around for a bolt-on fitment. Hope this helps! Let me know if you have any additional questions!
08-28-2017, 01:26 PM | #144 | |
3571
Rep 6,805
-Matt
08-28-2017, 09:57 PM | #145 |
Rep 192
08-29-2017, 11:33 AM | #146 |
3571
Rep 6,805
We currently have Anthracite in stock and ready to ship out. They are available on our website here!
-Matt
08-29-2017, 06:26 PM | #148 | |
3571
Rep 6,805
-Matt
08-31-2017, 02:18 PM | #149 |
3571
Rep 6,805
Check out these Satin Black 17x9" ET30 ARC-8 wheels in Satin Black.
09-15-2017, 01:33 PM | #150 |
Stand-up Philosopher
75
Rep 184
I'm interested in a set of 18" ARC-8's for my 2010 LCI E90 w/ Sport suspension.
I'd like to run 255's up front and 275's out back. I don't mind rolling or pulling my fenders but would like to avoid spacers if possible. Would you please recommend a size? Last edited by MooreBoost; 09-15-2017 at 01:43 PM.. |
09-16-2017, 09:06 PM | #151 |
Rep 16
I have a 2011 335is on BMW performance suspension. Can you confirm a square set of ARC-8s in 18x9 et30 with 255/35/18 Michelin PSS will fit without modification? If so, would you mind shooting me a quote for matte bronze with TPMS and the tires mounted, balanced and shipped to 65613? Thanks in advance!
09-18-2017, 02:29 PM | #152 | ||
3571
Rep 6,805
18" ARC-8 Staggered fitment: Front: 18x9" ET30 with 235/40-18 tires (direct fit) Rear: 18x9.5" ET35 with 255/35-18 tires (direct fit) * Front 255/35 tires can be used, but may require a 5mm spacer if you add coilovers later on. * Rear 275/35 tires can be used but will be very close to the fender and will likely require fender rolling or negative camber Let me know if you have any additional questions! Quote:
PM incoming!
09-25-2017, 05:44 PM | #153 |
Rep 59
Hello
For a LCI e90 18x9 et31 would be an ideal square setup for EC7s.. Im interested in a set of 18s in a square setup of ARC-8s.. Let me know what is an ideal wheel and tire specs for an LCI e90 square setup.. Also if you can post some pics of the matte bronze arc-8 on some e90s that would be awesome Thanks |
09-25-2017, 06:22 PM | #154 | |
1439
Rep 2,654
18" Square Setup: Front/Rear: 18x9" ET30 with 255/35-18 tires. * The ARC-8 wheels are ET30, and the EC-7 wheels are ET31, the 1mm is negligible and won't make a difference in fitment. Here are some photos of the Matte Bronze finish on an E90, we think it looks fantastic!
