01-16-2024, 04:06 PM | #5963 | |
Rep 4,297
I also have no sympathy for the morons that don’t precondition the interiors of their Teslas while complaining about how hard it is to open their door handles. |
01-16-2024, 04:08 PM | #5964 |
Rep 512
01-16-2024, 04:13 PM | #5965 |
Rep 177
MN is not that different from IL weather wise. I expect my appliances to work cold or not. Maybe tesla owen's can contact coustemer services to get this problem resolved 😉
Car-Addicted7315.50 eugenebmw1589.50 |
01-16-2024, 04:16 PM | #5966 | |
Rep 512
01-16-2024, 04:18 PM | #5967 |
Rep 19,957
Needless to say there's no EV's in my garage
01-16-2024, 04:20 PM | #5968 |
Rep 1,991
Drives: 2020 BMW M4 CS
Ruh Roh
Assessing the value of electric vehicle managed charging: a review of methodologies and results Unmanaged EV charging can stress existing grid infrastructure, possibly leading to operational, reliability, and planning challenges both at the Managed charging can support power system planning and operations during normal and extreme conditions, benefitting EV owners and other electricity consumers. However, the costs of enabling these services must be weighed against the benefits they provide. We summarize the benefits of managed EV charging, provide an overview of the landscape of existing implementations and costs of managed charging in the United States, critically review the state of the art of methodologies in analysis/modeling studies, and quantify the cost and benefits of managed charging as reported in the reviewed studies. Finally, we distill several key insights outlining the factors affecting the value of managed EV charging and identify critical gaps and remaining challenges to fully realize effective EV-grid integration. Active managed charging programs provide utilities, or a market aggregator working with charging networks, with the capability to determine and/or control charging time, scale, and location, “in order to achieve a variety of outcomes, such as managing peaks, absorbing excess renewable generation or supplying some ancillary services to a structured market.” These programs rely on a reliable two-way flow of information that includes 1) a transport layer which relies on a communication signal via Wi-Fi, cellular, vehicle telematics, etc. to send the charging instructions and 2) a messaging protocol or standard that can help the device understand and execute the instructions. https://pubs.rsc.org/en/content/arti.../ee/d1ee02206g You EV guys are so "F"ed Better get that Honda generator in your trunk. |
01-16-2024, 04:22 PM | #5969 | |
Rep 512
01-16-2024, 04:32 PM | #5970 | |
Rep 18,821
Car-Addicted7315.50 ///M Power-Belgium64686.00 |
01-16-2024, 04:39 PM | #5971 |
Rep 1,991
Managed EV Charging
Managed EV charging is an adaptive means of charging EVs which considers both vehicle energy needs and control objectives, typically designed to provide grid support or mitigate the impacts of EV charging. The benefits of managed charging range from reducing electrical equipment upgrades, maximizing the value of local generation, and reducing the cost of grid energy. Managed charging also ensures that fleet vehicles are properly powered when needed, while reducing unnecessary burden on the building infrastructure and supporting a more reliable and resilient grid. https://www.energy.gov/femp/managed-...mobile-storage That is government speak for we will allow you to charge your EV's if we don't need the electricity elsewhere. If you have a issue with that: Call the US Department of Energy. |
01-16-2024, 04:49 PM | #5972 | |
Rep 512
01-16-2024, 05:00 PM | #5973 |
Rep 1,991
Why you should not charge a lithium battery below 32 degrees
If you have a Lithium (LiFePO4) battery, there are some things to consider when charging under extreme temperature conditions. Lithium battery manufacturers often state an operational temperature range of -30°C to +80°C / -22°F to +176°F and an optimal temperature range of -10°C to +50°C / 14°F to 122°F (this varies depending on brand and model, consult your manufacturer). This is often misconstrued as a safe temperature range for both charging and discharging, this is not the case. The operational temperature range is referring to discharging the battery only. Charging a Lithium battery in ambient temperatures below 0°C / 32°F must be avoided. The reason for this is it may potentially damage the battery and / or reduce its lifespan. The optimum ambient temperature for charging a Lithium battery is +5°C to +45°C / 41°F to 113°F. When attempting to charge a Lithium battery below 0°C / 32°F a chemical reaction referred to as “Lithium Plating” occurs. Lithium plating is caused by the charge current forcing the lithium ions to move at a faster reaction rate and accumulate on the surface of the anode. When this chemical reaction occurs, the internal resistance of the battery increases and reduces the rate of chemical metabolism. This chemical reaction causes a permanent reduction of the battery’s capacity and will continue to reduce its capacity each time this reaction occurs. If you plan on using a Lithium battery in a location that may drop below 0°C / 32°F, you must be cautious as to when you attempt to charge the battery. Simply waiting for the temperature to raise during the day is a simple solution. Having the batteries mounted in a location that will have a higher ambient temperature than outside temperature is also advisable. https://www.redarcelectronics.com/us...ow-32-degrees/ |
01-16-2024, 05:00 PM | #5974 |
Rep 19,957
Meanwhile back over here in not too frozen Britain..
https://www.thesun.co.uk/motors/2282...-dont-want-it/ |
01-16-2024, 05:08 PM | #5975 |
Rep 340
Better not own a diesel truck either... negative double digits is gelled diesel fuel. Had to give an industry acquaintance a ride back from a ski resort because his truck gelled up in the parking lot on a really cold day last season...
01-16-2024, 05:18 PM | #5976 | |
Rep 1,991
Now this is cold! Here is what a new truck sounds like in -31 degrees Last edited by Car-Addicted; 01-16-2024 at 05:49 PM.. |
eugenebmw1589.50 ///M Power-Belgium64686.00 |
01-16-2024, 05:35 PM | #5977 | |
Rep 512
///M Power-Belgium64686.00 M5Rick61789.00 |
01-16-2024, 05:42 PM | #5978 | |
Rep 512
01-16-2024, 05:44 PM | #5979 | |
Rep 512
01-16-2024, 06:49 PM | #5980 |
Rep 4,297
https://twitter.com/dblcapcrimpin/st...935810/video/1
This man’s “Tesla” had to have a flat bed. The local Fox station interviewed him about his “Tesla”. |
01-16-2024, 09:47 PM | #5981 |
Rep 11,147
I don't watch YouTube... but when I do, it's diesel cold start videos!
01-17-2024, 04:16 AM | #5983 |
Rep 19,957
No response from Tesla when ppl were calling in and W TF is this pre condition the battery before charging, waiting for that you can freeze. In a gas car it's start and go.
I suspect the journo at the end is a greenie that was told what to say, saying that the problem is more attributed to the charge infrastructure than the 'robot' itself. |
01-17-2024, 04:25 AM | #5984 | |
Rep 19,957
