      05-01-2024, 09:13 AM   #1
pokrovsky
Drives: 2014 F06 M6 6 Speed
Strange issue (Manual Transmission)
I know that there aren't many of us here but perhaps someone has some ideas.
my F06 developed strange behavior, first I started to get warnings on the dash saying the Auto Start/Stop is malfunctioning. It would come and go and recently started to do it pretty persistently, but also, not sure if it's related (if so I really don't understand how that can be?) hill hold assist seems to not work anymore.
While auto start/stop is an annoyance as it's pretty pointless feature especially on a manual transmission car, hill assist is a handy feature
Any troubleshooting clues anyone?
Thank you!
2014 F06 M6 6 Speed, Frozen Grey, Zandvoort, Executive, Driver Assist Plus, Night Vision, Carbon ceramic brakes
      05-01-2024, 11:49 PM   #2
rotomoto712
Drives: 2008 BMW M3 Convertible
Wow. So I just went to check, and I didn't even realize that my manual had auto start/stop! It was set to off, and unlike modern BMWs, it must remember the last setting. Anyways, if you have access to ISTA or similar, I would run a scan and do diagnostics on the system. I don't think hill assist is related, but I am far from an expert on that.
      05-02-2024, 10:08 AM   #3
pokrovsky
Thanks, I do have a cable but it's been a while since I messed with BMW programming. I used to tweak my e90 335i all the time but leave this unicorn mostly alone
      05-03-2024, 08:41 AM   #4
JDMSteven
JDMSteven's Avatar
Drives: '13 F13 M6, '94 JDM Supra
2013 BMW M6  [9.75]
I believe you'll have an auxiliary battery under the trunk panel and when they get weak the auto stop start system can have issues.
2013 F13 ///M6 Alpine White • Zandvoort Full Merino Driving Assistance Pkg • Exec Pkg • Vent Seats
Vorsteiner VFF-103 Carbon Graphite 343M dimensions • H&R Lowering Springs • Soul PP Resonated Muffler Delete • AeroFunction AF-1 Carbon Front Lip • Carbon Front Grilles • Carbon Mirror Caps • IND Black Fender Vents
      05-06-2024, 11:11 AM   #5
pokrovsky
thank you!
      05-06-2024, 04:38 PM   #6
pokrovsky
Nope. No aux battery in my trunk
      05-21-2024, 02:15 PM   #7
pokrovsky
Just a follow up. It is not a battery issue. I replaced the battery as the original one was getting tired and showed 19% life on the BMW diagnostic tool at the dealer. Got the brand new OEM one and properly coded/registered.
The Auto start/stop malfunction didn't go away neither hill assist and then it dawned on me that I only see the issue of hill assist not working when this auto start stop warning comes up and it does work when there is no error. It must be related to some sort of a clutch pedal switch/sensor!!! I have not dug there and wanted to ask people here.
It makes tons of sense to be related in this case as failing sensor/switch will deem auto start and hill hold inoperable, right?!?!
Anybody has a service manual that indicates that part by any chance?
      08-08-2024, 09:48 AM   #8
pokrovsky
Just wantesd to follow up on the topic. Got some other tech diagnose the auto start stop issue and now they are telling me it is a neutral gear position swith of my manual tranny that is bad. It is located on top of the transmission and "the book" calls for transmission removal and hence obscene labor charge to get it replaces. Anybody experienced anything like this before?
There is no ill effects on driving just an annoying warning everytime I shut the car off telling me the auto start / stop function malfunction but I do want to properly address it.
Perhaps the subframe can be loosened that will allow access to the top of the transmission?
