06-06-2023, 08:28 AM | #1 |
Rep 6
2012 650i Adaptive LED - Left Low Beam and DRL Malfunction
Hello all,
Shortly after purchasing my 650 I lost the drivers side headlight. After a few trips to the small dealer I purchased the car from I have deemed them useless and will need to handle the repair. I have done a ton of research so I have a decent idea of common failures etc. but can't find much on this model specifically. Seems like the module under the light is a common failure due to moisture. Before I dig into this project I would like to know a few things as my research results are spotty at best. So first off - any advice or methodical troubleshooting techniques would be great. Here are a few more specific questions: In this year/model I assume the control module if replaced will need to be coded to the car. I would assume that the light would not work at all until this happens, is this correct? If so, what would be the best suited coding software that I could purchase to complete the job? Can any of the modules/parts be swapped side to side (with no coding) to assist in pinpointing the problem? Is there anywhere I can get an exploded view of the headlamp with part numbers? Every search I do leads back to the HID style headlamp. Another observation is that it acts as though there is a short, and the light is turning off for protection. For example if I turn on the high beams the light will come on for a second and then shut off. However it will not display an error for high beam, just low. Also, just FYI. This does happen in both auto and manual setting, additionally it was not an intermittent problem (since I have owned it). The low beam stopped working and has been out ever since (about a month). I could probably add more context but this is entirely to lengthy already. Thanks in advance! |
06-06-2023, 09:09 AM | #2 |
Rep 2,926
You can find the parts diagram and part numbers at RealOEM.com Just plug in the last 7 of your VIN, go to the Lighting section, and under there is a "Single Parts" diagram. You can check the part numbers to see if any are the same number for right and left.
06-06-2023, 09:15 AM | #3 |
Rep 2,926
I just looked at the instructions to replace the main module and it does require coding. ISTA is the best, but there are others. I've never obtained a program that can code at that level because I have not yet needed to. But there are a number of users here who have so they may chime in or you can run some searches in the forum or other forums since coding software is not model-dependent.
06-06-2023, 09:22 AM | #4 |
Rep 6
Thanks, that's a good start and all around useful tool.
06-09-2023, 07:21 AM | #5 |
Rep 303
Drives: 2017 BMW X5M
got the module if you need $300 from dealer I bought it n then lady crashed into my car so its been sitting lol im in ny
06-09-2023, 12:07 PM | #6 | |
Rep 6
I am looking for the 63117316216 (or 63117305236, original PN) according to the diagram (Fits 2010-2015 I think). is it new or used? Last edited by SoundWaves; 06-09-2023 at 05:31 PM.. |
06-10-2023, 09:42 AM | #7 | |
Rep 106
You can swap the modules over from the right headlight to see if it solves your problem (bit of a pain though as you have to take the bumper off, and reaching to some of those screws at the back of the headlight is a nightmare). Unfortunately, it didn't help in my case. My modules were fine. I ended up ordering a new headlight online and it solved the problem. I reckon you might have the same problem sorry to say.. It's an expensive pain that's for sure. |
06-10-2023, 03:12 PM | #8 | |
Rep 6
06-16-2023, 06:18 PM | #9 |
Rep 6
Well.. I was able to find a replacement assembly complete with modules on eBay for a "fair" price. Did the swap today using all my modules and everything is working like a charm! Not a bad project to swap, 2 of the headlamp screws are a bit tough but manageable. Thanks All!
06-17-2023, 04:12 AM | #10 | |
Rep 106
06-17-2023, 06:58 AM | #11 |
Rep 6
Wow, thats a deal. I paid a little over $1300 for the light and modules. Seems about the going rate these days for an empty one in decent shape. Happy to have some spare parts now too.
06-17-2023, 08:04 AM | #12 |
Rep 106
Ah yes I remember on eBay they were very expensive kinda in the range you mentioned. The only reason I replaced it is because I managed to find an "acceptable" price. But mine came without modules. Anyway, glad yours is working now, I know it's a relief!
