FORUMS
- 5
| 04-08-2012, 02:46 PM | #1 |
I need a new workout...
I am in need of a new workout, I am slipping in my fitness and it is showing.
Height: 5'10 Weight: 200lbs... Issues to consider: -I have shoulder impingement, I have a problem doing overhead stuff, I take a lot of time before workouts to stretch out with therabands, complex and akward lifts are not my thing. -My arms are great, genetics are on my side between bi and triceps, some people have to do a ton of each to see the results I have strength and appearence wise but I do not put a lot of focus on things like curls. -I hate cardio... I understand I need to incorporate some but where in the workout and what days as well as what I am doing needs adjustment so I don't burn myself out for the actual lifting part. -Though I am a bit old and still in school I work late sometimes and have an odd eating and sleeping regiment so some perfect diet and schedule isn't realistic. -I probably drink too often and don't really have a facts list of how bad it hurts my workouts. I didn't start going out drinking much until I was about 21 and kept a consistent weight of about 160-170lbs... I was not as strong but I was leaner for sure. I bet I probably end up drinking something alchoholic 3-4 days ish a week because I am stuck in a boring college town. I tend to do one day back and bicep, the next chest and tri but my chest seems to be suffering, I do enough weight that I feel my chest isnt being targeted enough and my triceps end up burning out before my chest really gets worked out... Here are examples of my workouts: BACK/BI: Standing curled bar curls: 3 sets of 12 reps @ 102.5lbs 8 @ 112.5lbs 6@ 122.5 lbs (for the last set I will curl a rep and bent row a rep until I hit 3-6) Seated shoulder raises: 3 sets of 12 @ 30lbs 35lbs and then 40lbs Bent over rows: 3 sets; 12 reps @ 112.5lbs 8 reps @ 122.5 and 132.5 for 6 reps Lat pull downs: 3 sets of 12/8/6 reps @ 100lbs, 115lbs, 130lbs (I go lighter because of my shoulder Seated rows: 3 sets 12/8/6 reps 80lbs-115lbs CHEST/TRI: I used to start off with 3 sets of 25 push ups as a warm up. Flat bench press: 12 @ 135lbs 10 @ 185lbs 8@ 205lbs and a few at 225lbs. (I used to max at almost 300lbs, hit 8-12 reps 225lbs... I think my workouts are too inconsistent I am not close to what I used to be on bench but I also am not as good at push ups as I used to. Skull crushers 3 sets 12 @ 102.5lbs 10 @ 112.5lbs and 6-8 @ 122.5lbs Incline bench: 3 sets of 12 @ 135lbs Tri pull downs: 3 sets 12 @ 72lbs 10 @ 80 lbs 8 @ 87lbs... I can't do fly's because it puts too much strain on my shoulders. So I sub with seated ones with the padded verticle forearm pieces. I do legs as well but am tired of typing and dont have a leg strength issue. I want a new functional well rounded workout. I need to lean up and fine tune some things, my workouts are boring I have done the same crap for years.
Thirty Past Three
| 04-08-2012, 05:26 PM | #2 |
| 04-09-2012, 02:33 PM | #3 | |
Thirty Past Three
| 04-09-2012, 03:57 PM | #4 | |
Good stuff. When doing the rack chins focus on your lats and bringing your elbows down and somewhat in.
| 04-10-2012, 09:42 AM | #6 |
I like Chris's training split. Has some good videos and describes the supplements to take. Good body transformation routine.
http://www.bodybuilding.com/fun/kris...ner-intro.html |
| 04-10-2012, 11:46 AM | #7 | |
JDM whore
| 04-10-2012, 01:06 PM | #8 |
Yeah, I'm dont like to follow any routine to a T. Everyone's body is different and responds differently to things. I take his training split and adhere to about 90% of it. Adding and taking away things that I like to do. I have a spinal fusion so anything that's overly strenuous on my lower back is out.
| 04-10-2012, 01:50 PM | #9 | |
JDM whore
| 04-11-2012, 02:37 AM | #10 | |
| 06-05-2012, 10:05 PM | #12 |
Grozniy
just do beachbody insanity
| 06-08-2012, 01:18 PM | #14 |
You sound like me in some ways. I was in the Marines and lifted for years. For the past 2 years I've been training BJJ and divide my small amount of regular gym time between weight lifting and stretching. I also do some hiking and kayaking etc. I've pretty much given up on lifting for it's own sake and am much happier overall. My suggestion is find hobbies that allow you to get a workout as well as knowledge/enjoyment. It's just more efficient. It really depends on your goals but this is what has worked best for me.
| 07-19-2012, 01:02 AM | #15 |
By your own admission it looks like your might be overweight? and should focus on getting healthy and lean first so when doing body weight based movements pullups, pushups etc you are lighter and there is less wear and tear on your already strained/damaged joints. Growing up I was super athletic and enjoyed all the benefits of being healthy. As I got older I let that slip and now have shoulder issues, forearm issues, knee issues, achilles tendon issues, all because
1. I was to big for my own good and was weightlifting to much without any real world purpose behind it besides getting big and strong. My old mindset was push more weight, get stronger where as now my mindset is more so what if i can deadlift 420lbs... id rather be able to deadlift 250lbs 20 times safely, controlled, strong and have no injuries and be healthy and feel good after) 2. once to big this caught up to me fast!!!! and I found myself frequently overtraining, this combined with also having a history of athsma my breathing was all fucked up as well. The results, I found i started having alot more injuries. I had to change my focus to being healthy (diet plus athletic focus workouts rather than just strength) and not just crazy strong and big. 3. I lost weight, i was around 245-250lbs and ended up getting to around 200 at 6'2 4. My joint pains which were actually debilitating for the most part went away which was HUGE for me, i went from doing around 50 pushups, 100 situps, 8-10 pullups with joint pain which would stop me, to doing over 100 pushups, 350+ situps, and around 40-50 pullups with no pain... all because i lost a shitload of useless weight and focused on functional strength, healthy eating. I could loose even more weight now ... maybe another 10 lbs as i have been lazy lately but overall i feel fast, lean, and healthy. I am comfortable where i am now and I can say my functional strength, cardio, and breathing, is hugly improved!! A couple ass kicker workout challenges I have tried for fun after getting my base cardio levels back had been: deadlift to burpee combos deadlift 110% your body weight 5 reps followed by 10 burpees (with pushup at bottom) repeat as many times as possible ( as you tire make sure you really focus on doing proper deadlift form !!) 100 Burpee challenge See how fast you can do 100 burpees with a pushup at the bottom. Alot of people do burpees down to plank/pushup position and dont do the pushup, well in this challenge do the pushup. You might want to puke , it might hurt a bit , but its worth it and a good challenge , give us your time at the end maybe we can start a forum challenge ![]() Do HIIT, Crossfit, etc - good for fitness, and functional body weight workouts. Last edited by M3Denver; 07-19-2012 at 01:23 AM. |
| 08-01-2012, 09:41 AM | #16 |
I hadn't worked out in years and recently started going with some friends. They are doing the 5-3-1 workout and I started doing that with them. I have been making some pretty good gains on it. Look it up and see what you think.
| 08-01-2012, 03:28 PM | #17 | |
![]() ![]() Drives: White 135i Join Date: Aug 2010
AUTOcouture Motoring| 15-01 Pollitt Drive #6 | Fair Lawn, NJ 07410 | P: 201.666.3500 | ACMallday@gmail.com
| Bookmarks |
| Thread Tools | Search this Thread |
