      12-21-2011, 12:41 AM   #1
roadsta
Drives: 2012 650i
Thumbs up Butterfly valve - 650i MSport exhaust
BIMMERPOST
     Featured on BIMMERPOST.com
There is a vacuum-actuated butterfly valve in one of the two exhaust openings on each side.
I think this is what makes that delightful sound in sport mode when the gearbox shifts up. (In another thread someone called it a 'booming sound')
It sounds open on a cold start too. When else does it open?
A few (poor) photos of the valve and the actuator:
      12-22-2011, 01:59 AM   #2
Soorena
Drives: M3 6MT
Get rid of it
if it's like other BMW's, it should open at 3500rpm.
      12-26-2011, 07:54 AM   #3
E90Fleet
South Africa
1312
Its actually there to make the exhaust sound less "boomy" at low RPM
It will open at higher RPM.
Its there to make the car quieter`at low RPM
BMW if you are reading, I need a job, Please.
      12-26-2011, 04:46 PM   #4
roadsta
Drives: 2012 650i
Thank you / Dankie.
This makes sense.
Also, on the cold start, I was wrong. I had a look the other day, the butterfly does not open. The exhaust probably just sounds noisier becuase of the higher engine revs at cold idle.
roadsta
