09-30-2020, 07:01 PM | #1 |
Rep 12
wheel specs
I dont understand much about rims.. would this config work for my 2012 650xi GC ?
Rim specs: Front: 20x9 ET 20 Hub bore: 74.1mm Rear: 20x10.5 ET 27 Hub bore: 74.1mm Bolt pattern: 5x120 |
10-04-2020, 10:09 PM | #2 |
Rep 289
Not sure about hub bore. Assuming hub bore fits our cars then fronts will fit. The rear is quite aggressive and will stick out the fenders ~13mm. They can fit but that's up to you if you like how much it will stick out.
edit: I don't think the hub bore will fit our cars but you might be able to get a hubcentric ring adapter. |
10-04-2020, 11:47 PM | #3 |
Rep 7,586
The F chassis six series wheel hubs are 72.56mm...so you’d definitely need to use hub centric rings Because the center bore of the wheels you posted are too large.
You can run your original front & rear wheel/tire setup through the calculator at this following link to compare what the “poke” & “inset” will be for the wheel/tire setup you’re attempting to install: www.willtheyfit.com
