Originally Posted by upstateX5M
nice. where did you get the diffuser? I was wondering how the 650 exhaust length would work with ///M diffuser. is that a 650 exhaust mounted with hangers in standard position or did you have to adjust?
That is the oem 650i exhaust.. no modification to the exhaust was needed other than cutting the square tips off. only problem is you cant just cut the two pipes out because you wont have enough space to clamp on the new tips. The vacuum flap assembly is too close.. only gives you a few inches to play with
